For Sale - Speedster Parts
Topic author - Posts: 509
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I have model B exhaust manifold with a model A intake and rebuilt carburetor setup. Had it running on my T but decided to put it back to stock. The setup comes with a new muffler and exhaust pipe professionally bent to make sure it does not hit the frame since it is larger than a stock T. The carburator has an adapter to take the carburator in closer to the motor, otherwise the carb sticks outside of the hood. Since the carburator is lower than stock there is no need for a fuel pump. There is no cutting or welding, everything bolts right up.
Pictures available on request since I can’t download them onto the website. I have way over a thousand dollars into the setup. Will take $ 700. Or best offer. Plus freight.
This setup will give more power and speed, especially on lower elevations, not like where I am at 5500 feet where it worked very well but decided to go back to stock T due to looks on my 12 towncar. Frank Seress. 818-254-6797
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Seress
- MTFCA Number: 27707
Re: For Sale - Speedster Parts
Thank you Tony. Frank
- Last Name: Seress
Everything is either new or rebuilt and has less then ten miles of operation while it was on my car. The exhaust pipe is even wrapped to reduce heat coming into the cab. Frank
- First Name: Bob
- Last Name: Doris
- MTFCA Number: 32538
To Top.
- Last Name: Seress
There must be someone out there that needs these parts.
- First Name: Patrick
- Last Name: Feeney
Hi, is the setup still available?
- Last Name: Seress
Patric, the setup is available. Frank
- Last Name: Seress
Patrick, look in your spam folder since this is the first time you have a mtfca conversation. Tony Bowker posted the pictures for me, that is why his name is on the post, you can varify it with him, but the setup is mine. Frank
