Hey all, I'm after a cad file or someone that has sketched up a detailed drawing for the rear drive axles. The only thing I have close to either is the image i've attached which I found on here.
Many thanks for any help
Cam from DownUnder
Model t rear axle: Cad or detailed drawings
Re: Model t rear axle: Cad or detailed drawings
Davey1916
Topic author - Posts: 13
- First Name: Cameron
- Last Name: Davey
- * REQUIRED* Type and Year of Model Ts owned: 1916 torpedo speedster
Thanks Steve unfortunately I'm after dimensions ect. But those drawings sure are cool!
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
That drawing you have is pretty basic, and obviously lacks much needed tolerances. An interesting method of defining the taper across the entire length of the axle too... IIRC, it’s 3/4” per foot with centerline taper, can’t help you with gauge diameter, but know you need to keep pretty tight tolerance on the taper to maintain overall axle length
Just use the Ford Service book. You don't need drawings.
Here is a link with an additional picture for cutting the key way
http://www.mtfca.com/discus/messages/50 ... 1231423423
