WHEEL BERG PACKER,
Topic author - Posts: 268
- Last Name: Grzegorowicz
WHEEL BERG PACKER,
I KNEW I HAD THIS ITEM , ITS USE FULL WHEN PACKING GREASE IN A WHEEL BERG, YOU STILL GET THE HAND GREASY BUT THE BERG'S GET FILLED
IT WILL PACK A GOOD SIZE BERG. BY PLACING THE WIDE SIDE OF BERG ON BOTTOM OF PACKER AND THREADING TOP HALF DOWN TIGHT MOUNT THE GREASE GUN TO THE FITTING AND PUMP , TO TELL WHEN BERG IS FULL OPEN COVER TO CHECK .IF NOT RE TIGHTEN COVER AND GIVE IT ANOTHER SHOT TILL IT IS, $20 PLUS POST ITS MADE SO YOU CAN REMOVE THE FITTING AND THRED THE GREASE GUN HOSE INTO TOP FITTING FOR A PERMANENT FIXTURE.-
- First Name: Kirby
- Last Name: Pray
Re: WHEEL BERG PACKER,
I’ll take it! I’ll pm you.
PACKER IS SOLD
- First Name: Jeff
- Last Name: Hood
- MTFCA Number: 25636
Both cones should be oriented in the same direction. The bearing gets greased and you can see that the grease has gone all the way through. You don't have to take it apart to see the bearing. Also uses less grease.
THANK YOU JEFF, I RELAY'D INFO TO KIRBY.
