Lifter guides
Posted: Thu Apr 07, 2022 2:26 pm
by RGould1910
When the lifter guides are bored to the max and there is still too much play, what do you use to bring the bores back to standard or at least the first OS?
I've heard of using a flange bushing with the flange at the bottom pressed into a circle milled out under the guide. Should be an easier fix with just a thin steel bushing.
What do folks do?
Re: Lifter guides
Posted: Thu Apr 07, 2022 2:35 pm
by speedytinc
RGould1910 wrote: ↑Thu Apr 07, 2022 2:26 pm
What do folks do?
The lifter bores get bored out for replacement lifter guides presses in, just like valve guides.
Press fit is enough. Not familiar with special flanged bushings & counter bores. Guides should be cast iron, not steel.
Re: Lifter guides
Posted: Thu Apr 07, 2022 5:37 pm
by pete eastwood
you could hard chrome the lifters oversize
Re: Lifter guides
Posted: Thu Apr 07, 2022 5:47 pm
by speedytinc
pete eastwood wrote: ↑Thu Apr 07, 2022 5:37 pm
You could bore to .500 & use .292/312 y block lifters. Thread them for an adjusting screw. One of my T's is running them now.
Re: Lifter guides
Posted: Thu Apr 07, 2022 5:54 pm
by Henry K. Lee
There is plenty of side access if you wish to use a set screw for piece of mind. Just Sayin'
Hank
Re: Lifter guides
Posted: Thu Apr 07, 2022 7:36 pm
by Les Schubert
Years ago I put model A lifters into a T block. Worked fine.
I am putting the Y block ones into a engine soon.
Re: Lifter guides
Posted: Fri Apr 08, 2022 6:45 pm
by TrentB
NOS Ford replacement T push rod guides look like this:
Respectfully submitted,
Trent Boggess
Re: Lifter guides
Posted: Sat Apr 09, 2022 10:46 am
by RGould1910
Great info and photos. Thanks.
Trent do you know if the lifter guides in the block are part of the block casting or are they separate pieces thar can be pressed out. If not then the block must be bored to accept the replacement guides, correct?
Much of my experience is with 09, 10 early 11 blocks with the removable guides.
Re: Lifter guides
Posted: Sat Apr 09, 2022 11:59 am
by Dan Hatch
Part of casting, must be bored out.
Any machine shop that can install valve guides can install lifter guides. Should even have a modern guide to do the job. Dan
Re: Lifter guides
Posted: Sat Apr 09, 2022 12:05 pm
by FATMAN
I have some nos guides,Bob
Re: Lifter guides
Posted: Sat Apr 09, 2022 1:55 pm
by TrentB
1909 to early 1911 open valve engines used replaceable brass push rod guides.
Trent Boggess
