09 Steering Column Shaft
Posted: Sat Dec 03, 2022 12:26 pm
Can anyone tell me the total length of the 1909-10 steering shaft that the pitman arm mounts to?
https://www.mtfca.com/discus/messages/29/24786.html
Robbie, I'm not sure this is what you are asking but I asked a similar question awhile back to a couple of people as I wanted to cut down a 5:1 steering gear to use in the early gear case and was told the gears won't fit. I was told I would need to use a later case and camouflage the case to look like the earlier housing.
This is the discussion about using a 5:1 steering shaft in a 4:1 case. https://mtfca.com/phpBB3/viewtopic.php?t=4747
I have 5:1 gearing in an original 14 gear case. Fits & functions fine. Heed fords warning. The center shaft, 3 planetary gears & the long shaft must all be 5-1. Do not mix any 4-1 pieces. The 3 gear pins are all the short length due to no machined travel stop slot in the gear case.BRENT in 10-uh-C wrote: ↑Tue Dec 06, 2022 5:36 pmRobbie, I'm not sure this is what you are asking but I asked a similar question awhile back to a couple of people as I wanted to cut down a 5:1 steering gear to use in the early gear case and was told the gears won't fit. I was told I would need to use a later case and camouflage the case to look like the earlier housing.
Brent,BRENT in 10-uh-C wrote: ↑Tue Dec 06, 2022 5:36 pmRobbie, I'm not sure this is what you are asking but I asked a similar question awhile back to a couple of people as I wanted to cut down a 5:1 steering gear to use in the early gear case and was told the gears won't fit. I was told I would need to use a later case and camouflage the case to look like the earlier housing.
