Just curious, what is Fluid Grease in differential
Posted: Fri Mar 17, 2023 3:45 pm
Reading the 1927 owners manual I saw
Lubricating the Differential
"Do not put too much grease in the differential housing. The housing should not be more than one-third full. The differential is supplied with the required amount of lubricant when the car leaves the factory.
The oil plug should be removed about every 1,000 miles and more grease added if necessary. If a fluid grease is used the level should be approximately one and one-half inches below the oil hole."
What is fluid grease.
