TT driveshaft coupler help
Posted: Sat Feb 10, 2024 5:57 pm
by KenHaverhill
Are there any differences in the coupler to connect a TT rear end to the driveshaft? We had a coupler in a working snowmobile with a ruxstell and Watford come apart .we had a spare stock rear end so we took the coupler off of it but it won't fit? Splines seem off.splines on rear end drive gear could have a twist I guess but look ok
Re: TT driveshaft coupler help
Posted: Sat Feb 10, 2024 6:09 pm
by Adam
There are 3 different splines for the worm gear / coupling / drive shaft and they don’t interchange; Early TT, Late TT, & Model A
Posted: Sat Feb 10, 2024 6:52 pm
by KenHaverhill
Thanks for the info Adam
Posted: Sun Feb 11, 2024 10:30 am
by Adam
Here are specifics on the TT variations:
1920:
Then, by 1924, they realize the mis-match causes problems and tell you not to do it!
1924:
The couplers began to be “marked” late 1924…
Later in 1924:
Posted: Sun Mar 22, 2026 12:21 pm
by tom_strickling
2 different depths of splines. I think you can use a deep coupler with a shallow splines shaft, but definitely not the other way around.
Posted: Tue Mar 24, 2026 9:36 am
by Jerry VanOoteghem
tom_strickling wrote: ↑Sun Mar 22, 2026 12:21 pm
I think maybe that's the other way around. The deep coupler has a minor diameter smaller than the minor diameter of the shallow spline shaft.
