TT driveshaft coupler help
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Post by KenHaverhill » Sat Feb 10, 2024 5:57 pm
Are there any differences in the coupler to connect a TT rear end to the driveshaft? We had a coupler in a working snowmobile with a ruxstell and Watford come apart .we had a spare stock rear end so we took the coupler off of it but it won't fit? Splines seem off.splines on rear end drive gear could have a twist I guess but look ok
Adam
First Name: Adam
Last Name: Doleshal
Re: TT driveshaft coupler help
Post by Adam » Sat Feb 10, 2024 6:09 pm
There are 3 different splines for the worm gear / coupling / drive shaft and they don’t interchange; Early TT, Late TT, & Model A
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
Post by KenHaverhill » Sat Feb 10, 2024 6:52 pm
Thanks for the info Adam
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sun Feb 11, 2024 10:30 am
Here are specifics on the TT variations:
1920:
Then, by 1924, they realize the mis-match causes problems and tell you not to do it!
1924:
The couplers began to be “marked” late 1924…
Later in 1924:
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Sun Mar 22, 2026 12:21 pm
2 different depths of splines. I think you can use a deep coupler with a shallow splines shaft, but definitely not the other way around.
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Post by Jerry VanOoteghem » Tue Mar 24, 2026 9:36 am
I think maybe that's the other way around. The deep coupler has a minor diameter smaller than the minor diameter of the shallow spline shaft.
