radiator
Posted: Thu Feb 22, 2024 7:25 pm
by ryanpad
So Ive ordered a radiator from Brassworks and Ill probably cut the nuts off to get the old one off the car.
My question is which hardware to use going back up? the car is a 1913 but I like the looks of the newer thimble design. (1920's)
Re: radiator
Posted: Thu Feb 22, 2024 7:36 pm
by RajoRacer
Simple plate, spring, stud, leather pad, nut & cotter pin. Thimbles won't work with a brass radiator !
Re: radiator
Posted: Thu Feb 22, 2024 7:38 pm
by ryanpad
RajoRacer wrote: ↑Thu Feb 22, 2024 7:36 pm
that answers that. thank you
Re: radiator
Posted: Fri Feb 23, 2024 12:03 am
by KWTownsend
Martyn Vowell,
Vincent needs your 1909-1916 radiator attachment diagram!
Re: radiator
Posted: Fri Feb 23, 2024 8:10 am
by DanTreace
KWTownsend wrote: ↑Fri Feb 23, 2024 12:03 am
Martyn Vowell,
The drawing by Martyn is right at Vincent’s fingertips.
Top of the Forum page, far right corner, click on ‘Gallery’, the click on ‘Vowell Art’, the select the file for ‘Radiator’, all the drawings are there to follow.
Re: radiator
Posted: Fri Feb 23, 2024 8:33 am
by jab35
Or from MTFCA Home page, Open these links: Resources-Drawings-Radiators
https://www.mtfca.com/phpBB3/app.php/gallery/image/94
Re: radiator
Posted: Fri Feb 23, 2024 4:31 pm
by ryanpad
very nice, the longer plate is key. I might not have had to cut the studs off if it was like that but 110 years....
Thank you
Re: radiator
Posted: Fri Feb 23, 2024 6:10 pm
by George Mills
I seem to recall that while mentally it sounds like a good idea...you can't do it!
I know, I tried and for some reason, even after some filing here and there, the hood would just not sit well. Struggled for hours...gave up...went back to leather pads and whoosh...all done perfect hood fit...fore and aft!
Good luck
Re: radiator
Posted: Fri Feb 23, 2024 6:22 pm
by ryanpad
George Mills wrote: ↑Fri Feb 23, 2024 6:10 pm
Good luck
THANKS GEORGE, I'LL GO BACK TOGETHER WITH THE ORIGINAL DESIGN. I DO WANT TO INSURE THAT ITS ISOLATING AS INTENDED AND EASY TO REMOVE. THE 110 YEAR OLD SYSTEM WAS NEITHER.
Re: radiator
Posted: Sat Feb 24, 2024 1:57 am
by Allan
The longer plate in the frame rail is a good idea. It will not turn when assembling the rest. I usually put the spring in the frame rail, put the stud through it and screw it into the plate, then fit the split pin.Then I wind the stud out until it binds the pin on the bottom of the plate. This gives you maximum length of stud when fitting the rest of the assembly. I also use insertion rubber instead of leather because leather dries out, shrinks and hardens.
Hope this helps.
Re: radiator
Posted: Sat Feb 24, 2024 11:26 am
by George Mills
Yes Allan I do believe your advice is even more correct. In my case the decision was made late at night, I just took a full hide belt from the closet and 'crafted' the pads to fit. Had I thought it through, or now that I hear your way, I too would have gone with EPDM Rubber. (The flat roof stuff...it is impervious to most anything when it comes to 'aging' as long as UV is not your culprit)
Re: radiator
Posted: Sat Feb 24, 2024 5:37 pm
by ryanpad
George Mills wrote: ↑Sat Feb 24, 2024 11:26 am
Yes. I was going to ask if we were substituting rubber for leather
Re: radiator
Posted: Sat Feb 24, 2024 6:32 pm
by Allan
Vincent an easy fix any time you lift the radiator. Not so for your belt though!
