radiator
Topic author - Posts: 104
- First Name: Vincent
- Last Name: Ryan
- * REQUIRED* Type and Year of Model Ts owned: 1913 TOURING CONVERSION
- Board Member Since: 2023
radiator
So Ive ordered a radiator from Brassworks and Ill probably cut the nuts off to get the old one off the car.
My question is which hardware to use going back up? the car is a 1913 but I like the looks of the newer thimble design. (1920's)
Re: radiator
Simple plate, spring, stud, leather pad, nut & cotter pin. Thimbles won't work with a brass radiator !
- First Name: Keith
- Last Name: Townsend
Re: radiator
Martyn Vowell,
Vincent needs your 1909-1916 radiator attachment diagram!
Re: radiator
The drawing by Martyn is right at Vincent’s fingertips.KWTownsend wrote: ↑Fri Feb 23, 2024 12:03 amMartyn Vowell,
Top of the Forum page, far right corner, click on ‘Gallery’, the click on ‘Vowell Art’, the select the file for ‘Radiator’, all the drawings are there to follow.
- Last Name: Bartsch
Re: radiator
Or from MTFCA Home page, Open these links: Resources-Drawings-Radiators
https://www.mtfca.com/phpBB3/app.php/gallery/image/94
- Last Name: Ryan
Re: radiator
very nice, the longer plate is key. I might not have had to cut the studs off if it was like that but 110 years....jab35 wrote: ↑Fri Feb 23, 2024 8:33 amOr from MTFCA Home page, Open these links: Resources-Drawings-Radiators
Thank you
- Last Name: Mills
Re: radiator
I seem to recall that while mentally it sounds like a good idea...you can't do it!
I know, I tried and for some reason, even after some filing here and there, the hood would just not sit well. Struggled for hours...gave up...went back to leather pads and whoosh...all done perfect hood fit...fore and aft!
Good luck
Good luck
- Last Name: Ryan
Re: radiator
THANKS GEORGE, I'LL GO BACK TOGETHER WITH THE ORIGINAL DESIGN. I DO WANT TO INSURE THAT ITS ISOLATING AS INTENDED AND EASY TO REMOVE. THE 110 YEAR OLD SYSTEM WAS NEITHER.George Mills wrote: ↑Fri Feb 23, 2024 6:10 pmI seem to recall that while mentally it sounds like a good idea...you can't do it!
Good luck
Re: radiator
The longer plate in the frame rail is a good idea. It will not turn when assembling the rest. I usually put the spring in the frame rail, put the stud through it and screw it into the plate, then fit the split pin.Then I wind the stud out until it binds the pin on the bottom of the plate. This gives you maximum length of stud when fitting the rest of the assembly. I also use insertion rubber instead of leather because leather dries out, shrinks and hardens.
Hope this helps.
Hope this helps.
- Last Name: Mills
Re: radiator
Yes Allan I do believe your advice is even more correct. In my case the decision was made late at night, I just took a full hide belt from the closet and 'crafted' the pads to fit. Had I thought it through, or now that I hear your way, I too would have gone with EPDM Rubber. (The flat roof stuff...it is impervious to most anything when it comes to 'aging' as long as UV is not your culprit)
- Last Name: Ryan
Re: radiator
Yes. I was going to ask if we were substituting rubber for leatherGeorge Mills wrote: ↑Sat Feb 24, 2024 11:26 amYes Allan I do believe your advice is even more correct. In my case the decision was made late at night, I just took a full hide belt from the closet and 'crafted' the pads to fit. Had I thought it through, or now that I hear your way, I too would have gone with EPDM Rubber. (The flat roof stuff...it is impervious to most anything when it comes to 'aging' as long as UV is not your culprit)
Re: radiator
Vincent an easy fix any time you lift the radiator. Not so for your belt though!
