Setting the beat on a Howard Miller clock
Last Name: Patrick
Post by jiminbartow » Fri Nov 25, 2022 9:07 am
I have a circa 1995 Howard Miller tall case grandfather clock that has an uneven beat that is very difficult to get right. Does anyone know how to set the beat so that it is an even tick-tock instead of a tick-TOCK. I am unable to adjust it by tweeking the pendulum and it will not adjust automatically by starting the pendulum at the far side of one side or the other, so there must be an adjustment on the movement inside the case. Thank you. Jim Patrick
Re: Setting the beat on a Howard Miller clock
Post by Scott_Conger » Fri Nov 25, 2022 10:50 am
email sent
Last Name: Patrick
Post by jiminbartow » Mon Nov 28, 2022 5:29 pm
Hi Scott. Thank you for your troubleshooting email. It did the job and the beat of my clock is even as it should be. Thanks again. Jim Patrick
