I once bought a Model T and the seller insisted, I would need to get some supplement to replace the lead in non-leaded gas. I told him that leaded gas came out after the Model T era was over. He didn't believe me.
Her is an article that I read today on the inventor of leaded gas:
https://www.jlconline.com/business/thom ... inventor_o
I found it in here :
https://www.jlconline.com/projects/remo ... tre-dame_o?
Ethyl gas
Herb Iffrig
Topic author - Posts: 1772
- First Name: Herb
- Last Name: Iffrig
Re: Ethyl gas
Leaded fuel is wonderful stuff. It will do no harm in a T, but it isn't needed. Model T engines, whether stock or near stock, run at very low stress and will accommodate low octane fuel quite well. Exhaust valve recession is not an issue with T engines except where the valve doesn't seat properly or is run with too much clearance for a very long time.
