ID an oddball carb?
Duey_C
First Name: Duane
Last Name: Cooley
ID an oddball carb?
Post by Duey_C » Fri Aug 02, 2024 11:55 pm
Would you guys have a look at this carb?
We’re stumped.
Brass float inside of course. With a gear drive adjustable main jet?
1. Apparently, all casting numbers start with M.
2. M3767 sediment “bowl”.
3. A Fairbanks Morse like flutter valve yet a hole below. Adjustable.
Look here if you wish to. Short thread and easy to navigate.
https://www.smokstak.com/forum/threads/ ... st-2007300
The guys are at a steam show in Maryland I believe.
Your thoughts?
Thank you!
First Name: Adrian
Last Name: Whiteman
Re: ID an oddball carb?
Post by A Whiteman » Tue Aug 13, 2024 6:53 am
'No Idea'
But the gearing would give a very fine adjustment, maybe for a slow running engine?
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Tue Aug 13, 2024 7:20 pm
Interested. Sent email
