Anderson Timer
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Anderson Timer
Post by Dennis_Brown » Mon Jun 01, 2020 4:08 pm
Looking thru some old timers I noticed the Anderson Timer has a smaller diameter circle for the contacts. What does the roller assembly look like that attached to the cam compared to other roller assemblies?
First Name: Adrian
Last Name: Whiteman
Re: Anderson Timer
Post by A Whiteman » Mon Jun 01, 2020 5:46 pm
Anderson timers use a 'flapper' rather than a roller. The flapper swipes across the contact spot in the timer instead of 'rolling' or 'rubbing' around the edge as regular timers with rollers or brushes do.
It seems you either like them or you don't. I like them and have had good running experience (i.e. no problems, always work, last a long time).
Anderson flapper:
Roller:
Brush:
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
Board Member Since: 2014
Re: Fronty head
Post by Rjackson » Mon Jun 01, 2020 8:03 pm
Is there a group of guys that have parts and just talk or is there a club where I can talk to these guys that run frontys
ModelTMark
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Re: Anderson Timer
Post by ModelTMark » Tue Jun 02, 2020 11:46 pm
I have an original Anderson timer with all the company patient data embossed that Frank Fenton rebuilt for me like 15 years ago, and it works like a champ. Frank was reproducing the Anderson Timer back when he and I were on the MTFCI board of directors.
MKossor
Last Name: Kossor
Re: Anderson Timer
Post by MKossor » Wed Jun 03, 2020 12:27 am
Dennis, a more recent approach is a Vane actuator used by the I-Timer. Rather than a roller, flapper or brush; the 4 magnets tell the Timer which coil to activate and the windows cut in the outer diameter tell the timer when to activate the coil without any physical contact so its maintenance free and never wears out. A single sensor is used to detect window openings so the Vane actuator is immune to timing cover misalignment about the CAM (concentricity) to minimize coil to coil timing variations.
I-Timer Vane Actuator.JPG (20.03 KiB) Viewed 2919 times
