A steel Hayes wheel. That's all I know :(
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Post by csnailnrun » Tue Jun 02, 2020 9:45 am
I picked a pair of these up at an auction several years ago. I've since blasted, primed, and painted. Ideally I'd like to find two more to make a full set, but first I need to learn what type of rim and lugs are required. Save yourselves a lot of typing... Pictures is a thousand words :D
Re: A steel Hayes wheel. That's all I know :(
Post by Mark Gregush » Tue Jun 02, 2020 10:10 am
Wow on the cool factor! I have seen sets of other brands like Atlas, but I think these are a first.
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Tue Jun 02, 2020 12:54 pm
Thanks Mark! Just imagine the cool factor increase once they are mounted😁😁
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Post by Howard Tomlinson » Tue Jun 02, 2020 4:35 pm
I have one of those!
Picked it up at Hershey years ago when the Green Field was un-paved. Must have had a 2 mile hike back to the truck and that thing weighs a TON!
Mine still has the front hub installed, but like yours...no rim.
Howard
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Tue Jun 02, 2020 4:44 pm
Does a standard Hayes 23" demountable rim fit on it? Very cool. Looks similar to the Parker steel wheels.
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Tue Jun 02, 2020 8:35 pm
I'm not sure if I have a standard Hayes 23". Would you mind sharing a photo?
Howard, I assume the front hub is the T hubs right? I started to slide slide a refurbished one in but backed off to not scratch either as I was not ready to bolt everything up.
Howard Tomlinson
First Name: Howard
Post by Howard Tomlinson » Tue Jun 02, 2020 9:26 pm
Hello Ryan,
It looks like a standard T hub, but I have never taken it apart to check it.
Chris,
I also have some Parker-Hydraulic steel wheels. The Parkers spokes are made of pressed steel and the wheels don't have a fellow that stays with the spokes. The Hayes spokes are cast (steel or iron) and have the typical demountable fellow attached (fellow is riveted to the spokes). The Hayes do weigh a lot!
Howard
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Thu Jun 04, 2020 11:01 am
Anyone running a set of these or know the appropiate lugs and rims?
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Wed Jun 10, 2020 8:46 am
Hump day bump!
Post by DanTreace » Wed Jun 10, 2020 7:49 pm
Ryan
That felloe is marked Hayes and has the notches for the Hayes fixed lug clincher rims, those are std. T supplied rims, and very easy to find. 30" x 3 1/2".
Haynes demountable rim on Hayes notched felloe.
Haven't seen any details on that solid 6 spoke wheel you have, maybe the mfg. wasn't Hayes, but the company bought Hayes rims to rivet to their wheel product, would be reasonable to have a common T felloe.
Did find this type, but 8-spoke, and a later ad that had this wheel without a center hub and drum. Maybe the mfg. of yours perhaps came out with a even lighter 6-spoke ??
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Thu Jun 11, 2020 10:03 am
Thank you for your input Dan. I'll looking for the clinchers you recommend and hope for a happy marriage!
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Thu Jun 11, 2020 6:45 pm
I have had one of these wheels for years. It was in the back seat of a 1924 Tudor that I purchased. I have not been able to identify the manufacturer, other than the Hayes name on the rim. The center spokes are riveted to the rim and are cast or forged steel. One the back side of the casting is the number B-AA-177. I hope this helps,
Russ Furstnow
000_0003 (640x544) (400x340).jpg (67.4 KiB) Viewed 5213 times
