What is the difference between a "EE" Crankshaft and a regular crankshaft?
How are they identified?
What's the advantage, if there is one?
Thanks,
Dave
"EE" Crankshaft
Topic author - Posts: 25
- Last Name: Loving
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring; 1911 Torpedo; 1923 Roadster
Re: "EE" Crankshaft
Metal properties - EE cranks are marked either in the casting between the throws and/or stamped into the snout. Been known to be a superior crank compared to the earlier "diamond" throw crankshafts.
- First Name: Adam
- Last Name: Doleshal
Re: "EE" Crankshaft
AA cranks are vanadium steel
EE cranks are high carbon steel
AA is more prone to cracks and breakage but less prone to wear.
EE is generally a bit more durable but more susceptible to wear.
Its less likely to find cracks in a used EE crank, but many used EE cranks wear a lot at #3 main and the wear is generally off center, so if the wear there is .007”, the crank usually won’t clean up at -.020” (if the crank grinder is correctly centering off the flange and not the remaining journal).
Re: "EE" Crankshaft
Just don't rely on an EE crank not being cracked. It should still be tested, and discarded if it fails the test. I had two put away for future use. When tested, both were cracked, either side of third rod journal.
- Last Name: Bartsch
Re: "EE" Crankshaft
And both types are forgings, not just simple castings, correct?
