A part found- what is it?
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Thu Jun 11, 2020 10:30 pm
A friend found this small brass looking plaque and I thought someone on the forum might know it's source. His description: "The size can be estimated by the size of the quarter. It’s about 1/8 inch thick, and the it looks like the back side has a coating of solder on it."
Does anyone know this part's original usage?
unknown logo.jpg (15.49 KiB) Viewed 4535 times
dobro1956
First Name: Donnie
Last Name: Brown
Re: A part found- what is it?
Post by dobro1956 » Thu Jun 11, 2020 10:49 pm
I'm pretty sure it is a Model A Ford radiator shell emblem
Scott C.
Last Name: Clements
Post by Scott C. » Fri Jun 12, 2020 12:49 am
It looks like the hood emblem from an 8N Ford tractor.
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Fri Jun 12, 2020 9:21 am
Charles says the badge appears to be copper.
SteveTN
Last Name: in Tennessee
* REQUIRED* Type and Year of Model Ts owned: '23 Cuttoff
Post by SteveTN » Fri Jun 12, 2020 10:32 am
I thought the Model A radiator shell emblems were steel with blue porcelain - except 31 which were painted I think. But still steel.
If Model A it should be 2 31/32 wide and 1 15/32 tall. Or so I think.
I vote for 8N or 9N emblem.
Now you just need a tractor to go with it, but make sure you get a PTO clutch when you hook the bush hog up to it!!!
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Jun 12, 2020 10:41 am
Looks like a tractor badge minus the chrome plating.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Jun 12, 2020 10:49 am
It's a Model A badge.
It's spent a long time in the ground.
The blue cloisonne (porcelain) is gone.
They were nickel or chrome plated over copper or brass. You can see evidence of this on my example where the porcelain is chipped.
The solder on the back is for the stud.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Jun 12, 2020 10:51 am
Here is a 1932-35 Ford truck badge.
Note the copper/brass where the cloisonne is missing.
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Fri Jun 12, 2020 5:03 pm
Thanks friends! I think he tends to agree with you.
Bill :shock:
