Order of assembly front sheet metal 26/27
signsup
Last Name: Brough
Post by signsup » Tue Feb 12, 2019 3:07 pm
Restoring a depot hack and the PO just cobbled this thing together, so how it was does not mean the way it should be. I've got the front end sheet metal pieces:
radiator
front apron
two hood shelf/engine pan triangles
front fenders
Starting with the frame , going up, up, what would be the correct order of assembly?
Thanks in advance.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
Last Name: Humble
Board Member Since: 2006
Re: Order of assembly front sheet metal 26/27
Post by Humblej » Tue Feb 12, 2019 4:54 pm
Fenders first, then hood shelf, then lower radiator apron, then radiator.
jab35
Last Name: Bartsch
Post by jab35 » Tue Feb 12, 2019 5:40 pm
And, if the correct hood hold down springs and washers are used, the hold downs may be installed in the hood shelves and blocks before installing the shelves on the car, which is somewhat simpler than compressing the springs after the shelves are installed. jb
Post by DanTreace » Tue Feb 12, 2019 7:35 pm
;) Our Resident Artist has that covered too
ArthurB
First Name: Arthur
Last Name: Babitz
* REQUIRED* Type and Year of Model Ts owned: 1927ish Roadster Pickup
Post by ArthurB » Tue Feb 12, 2019 8:04 pm
I just completed this assembly on my 1927 Roadster using the VowellArt diagram. It helped to precompress the bottom springs on the radiator studs by placing washers underneath the lower end of the mounting stud. 3 or 4 washers did the trick for me, though it takes some effort to get them in there. Those springs are awfully stiff.
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Wed Feb 13, 2019 6:54 am
To compress those radiator springs, I just took a wood wedge and tapped it in to to the trick. Once the installation was complete, they were easy to remove.
signsup
Last Name: Brough
Post by signsup » Wed Feb 13, 2019 8:50 am
To the workshop!
One other quick question. The hood shelves color. If the body of the car were a different color than black, I presume the radiator apron with the nickle strip trim would be the body color as well as the fenders. The radiator is black and the shell is nickle. What would be suggested for the hood shelves? I could paint the shelf area a different color than the flat sheet metal area. I don't know if this part is considered more of a frame part or a body sheet metal part. My frame is black the body will be dark green.
Not enough contrast between the two to really make much of a statement, but I'm thinking the pan area green as it blends into the fenders and the shelf area and hold down clips are black and the hood will be green.
Should my hood clips be nickle or something other than black?
Thanks to all.
A bunch of old cars
Sometimes they run.
Post by Norman Kling » Wed Feb 13, 2019 11:26 am
The fenders, splash shields, radiator splash apron, and hood shelves are all black even on colored body cars.
