Survey
ModelTWoods
First Name: Terry
Last Name: Woods
Survey
Post by ModelTWoods » Sun Jun 14, 2020 1:00 am
Just would like to see the results. I know some of you say "just use all steel plates in the transmission the way the factory built them'. There are others who want a more positive neutral without having to be a master T mechanic and fine tune a transmission, so, for those not using all steel plates, what is your preference: Turbo 400 style discs, or Watts/Jack Rabbit type discs?
Bands? Cotton (Scandinavia), or Kevlar? (not considering wood or anything else)
First Name: Keith
Last Name: Townsend
Re: Survey
Post by KWTownsend » Sun Jun 14, 2020 1:56 am
Watts clutch
Kevlar
First Name: Adrian
Last Name: Whiteman
Re: Survey
Post by A Whiteman » Sun Jun 14, 2020 5:19 am
Steel
Kevlar
(positive neutral too)
Ron F
First Name: Ronald
Last Name: Fishback
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1926 Touring, 1926 Pickup
Re: Survey
Post by Ron F » Sun Jun 14, 2020 7:26 am
turbo 400 in 1916 Touring, 1926 Touring and 1926 Pickup.
Ron F
Last Name: Strange
Re: Survey
Post by CudaMan » Sun Jun 14, 2020 7:59 am
My Betsy came to me with a Jack Rabbit clutch. I have no complaints about it. It is "grabby" compared to the stock all-steel clutch, so I have to ease it into high instead of letting the pedal "snap" up.
I have a Watts clutch on the shelf if the Jack Rabbit ever gives out. Sorry, it isn't for sale. :)
Adam
First Name: Adam
Last Name: Doleshal
Re: Survey
Post by Adam » Sun Jun 14, 2020 11:51 am
Just a little food for thought here...
Survey results can be biased. They are the opinions of people who answer surveys...
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Survey
Post by ModelTWoods » Sun Jun 14, 2020 3:50 pm
Opinions are obvious, and if a
person likes what he has, they can be biased, but that kind of information is what I wanted to hear and read. I have my opinions and biases, too. I just wanted to see how many owners thought along my lines.
George N Lake Ozark
First Name: George P
Last Name: Clipner
Re: Survey
Post by George N Lake Ozark » Sun Jun 14, 2020 6:49 pm
400 clutch/ Kev.bands.
Kerry
Last Name: van Ekeren
Re: Survey
Post by Kerry » Sun Jun 14, 2020 7:00 pm
I rebuild several T's a year. always fit and recommend modern clutch packs to the owners. I push T's in and out of the shop every day to get working room, something that is not easy with the original clutch when one is a senior :(
Adam
First Name: Adam
Last Name: Doleshal
Re: Survey
Post by Adam » Sun Jun 14, 2020 7:25 pm
That’s what I tell telephone surveys...
The answer here is:
-Kevlar bands
-New ductile iron low drum
-Original Ford reverse and brake drums are okay if in good condition.
-Original Stock Ford clutches that have been properly cleaned, inspected, and qualified.
-Original clutch spring that tests 95#’s or better at 2” compression.
ModelT46
First Name: Darel
Last Name: Leipold
Re: Survey
Post by ModelT46 » Sun Jun 14, 2020 7:29 pm
Steel works great.
Darel
ModelT46
First Name: Darel
Last Name: Leipold
Re: Survey
Post by ModelT46 » Sun Jun 14, 2020 7:30 pm
I use always a NOS sprig.
