TT Truck Running Boards
jeffstag
Last Name: Versteeg
* REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Post by jeffstag » Tue Jun 30, 2020 11:21 pm
Does anyone know when the TT running boards switched to the 'boot scrapper' style? Was that early '26 or did that come in in '25?
I'm getting set to dive into a '25 project (June '25, since I've got the engine) and I'm taking inventory, so I've got several TT parts questions that I haven't figured out already, but I'll try and space them out so I don't flood the forum with little nitpicking questions
23 Touring
23 Fordor
25 TT
27 TT
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: TT Truck Running Boards
Post by D Stroud » Wed Jul 01, 2020 1:01 am
Jeff, I THINK the boot scraper running boards came out in '24 with the introduction of the high radiator. I could well be wrong, I'm sure others will chime in here. Dave
1925 mostly original coupe.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Wed Jul 01, 2020 9:30 am
Like David, I too THINK it was about 1924. You must remember that old style parts were used up until gone, then the newer style was introduced into production. This suggests that the boot scraper style may nor have appeared everywhere at the same exact time.
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Post by abcarswell » Wed Jul 01, 2020 10:12 am
My ‘24 with a high radiator has short running boards. It’s not inconceivable that these were not original to the vehicle. Based on my research, the change over to boot scraper appears to have occurred late ‘24 or early ‘25.
Post by Original Smith » Wed Jul 01, 2020 10:18 am
I really like TT trucks, but have never owned one. My question is was the C cab offered in 26-7 along with the closed cabs?
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Wed Jul 01, 2020 10:25 am
Yes it was.
Brad
Post by RajoRacer » Wed Jul 01, 2020 10:54 am
I'm the caretaker of a "family owned since new" Dec. '23 (1924 model) TT C-Cab Express - it has the shorter running boards.
grandpa's truck0001.jpg (27.45 KiB) Viewed 8978 times
jeffstag
Last Name: Versteeg
Post by jeffstag » Wed Jul 01, 2020 11:07 am
It looks like they appear in the parts book starting Dec. 1925. So maybe a mid-year '25 change (?) There were some changed made mid-25 when the close cab came out, so maybe early 25 (?) I'm not sure how much lag there is between a part showing up on a car and it appearing in the parts book
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
Last Name: Versteeg
Post by jeffstag » Wed Jul 01, 2020 11:45 am
I've been looking at pictures of closed cab trucks online that look like they're original. The ones that are supposedly 1925 seem like about half and half short vs long running boards, so I'm starting to think this was a more later '25 change. My 'June' truck should probably have the shorter ones then. I'm going to save a pair of long ones in case I change my mind, though, since you can't trust most of the internet.
Who has original 1925 trucks? What running boards do you have? What month was your truck made?
23 Touring
23 Fordor
25 TT
27 TT
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Wed Jul 01, 2020 2:48 pm
I have a TT C Cab with the engine dating to August 1, 1925 and it has short running boards. I am fairly certain that the engine is original to the truck.
That would make it an early '25, but I think the '24 and '25 TT's were the same for both years. Maybe the running boards were a running change?
For what it's worth...
Keith
jeffstag
Last Name: Versteeg
Post by jeffstag » Wed Jul 01, 2020 3:19 pm
Actually confirms that the change to the long 'boot scraper' boards was a late (post August) '25 change.
23 Touring
23 Fordor
25 TT
27 TT
kelly mt
Last Name: Kelly
Post by kelly mt » Wed Jul 01, 2020 4:11 pm
What running board is this on m y '25? I'm not up on the different types.
Post by DanTreace » Wed Jul 01, 2020 4:43 pm
The Aug. 1925 Parts Books lists the short boards, L and R.
And this nice photo shows good view of the short board with boot scraper upset end flare.
Click on photo to enlarge
Post by RajoRacer » Wed Jul 01, 2020 8:31 pm
Not correct there, Dan - short boards were interchangeable - it lists 1925 L. & R. which is the "new" style.
Post by RajoRacer » Wed Jul 01, 2020 8:32 pm
Us folks with TT's refer to those as the long boot scraper boards.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Wed Jul 01, 2020 8:54 pm
I learn something new every day. Never paid attension to the 26 runningboards on my next TT project. Boot scrapers. 23 has short ones. Thanks for all the info.
Post by RajoRacer » Wed Jul 01, 2020 9:26 pm
Your truck is sporting the short boards, Pat.
jeffstag
Last Name: Versteeg
Post by jeffstag » Wed Jul 01, 2020 10:03 pm
So it looks like what I'm getting is that the long boards first appeared in the August '25 parts book and started appearing on the trucks at that time or very shortly thereafter. That syncs with the '25's I'm seeing being about half and half (unscientific and small sample size)
23 Touring
23 Fordor
25 TT
27 TT
Post by Original Smith » Thu Jul 02, 2020 10:03 am
Steve: Knowing you, you probably have the correct battery box and cover on you TT truck. How about posting a picture of it?
Post by RajoRacer » Thu Jul 02, 2020 10:06 am
Sorry Larry, I don't - it was long gone before I inherited it !
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Thu Jul 02, 2020 11:54 pm
My unmolested 25 had the short boards. My Jan 26 built truck has the long ones.
30Advance
First Name: David
Last Name: Vanek Jr
* REQUIRED* Type and Year of Model Ts owned: 1925 Ford Model TT C-Cab Express
Post by 30Advance » Wed Jul 08, 2020 1:30 pm
My '25 TT C-Cab Express has the Short Running Boards. The research I did at the Henry Ford Museum Archives etc. all leads me to believe that the long running boards were produced for the '26 - '27 Model Year Trucks. I bet some very late '25 had them as well but Never say Never.
My 2 cents,
Dave
JunkyJud
First Name: Justin
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 1924 TT C cab
Post by JunkyJud » Fri Jul 10, 2020 7:57 am
From all of the factory photos I have seen, I believe that the long boot scraper boards were used for closed cabs and short boards were used for C cabs throughout both of their production runs.
Short boards actually have two variations: one to be used with wood blocks and one to be used without. The difference is a small cut out on the inner lip of the board for those without wood blocks. The cut out allows the board to sit down over the mounting bracket.
Justin in Western PA
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Fri Jul 10, 2020 9:54 am
I'm reasonably certain that Justin is right. Short vs. long running boards was a function of the cab style once the long boards were introduced.
Corvette Guy
Last Name: Jones
Post by Corvette Guy » Fri Jul 10, 2020 8:41 pm
Can someone post photos side by side of the differences?
JunkyJud
First Name: Justin
Last Name: H
Post by JunkyJud » Fri Jul 10, 2020 10:07 pm
Here is a thread from a few years ago with a lot of good pictures and more discussion about TT running boards:
http://www.mtfca.com/discus/messages/59 ... 1451757467
