Can’t remove roller bearing from driveshaft spool
Wwbbim
Topic author - Posts: 15
- First Name: Jace
- Last Name: Jensen
- * REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
The roller bearing on my driveshaft is stuck inside the spool. Is there any specific way to get it out? Something is blocking its way out the front of the spool and I know it’s supposed to be able to come out but i don’t know how to take it.
- Attachments
- AED72A1C-481A-489C-971E-3223AD5B3E92.jpeg (29.39 KiB) Viewed 1890 times
- B67E8B18-51D8-489E-AB61-795AECCF2133.jpeg (29.22 KiB) Viewed 1890 times
- 499FBBA6-524B-4976-8039-26DD0F8C5BB5.jpeg (32.07 KiB) Viewed 1890 times
- 8D740ECA-BCA5-4324-B84B-611F663DBCCA.jpeg (29.95 KiB) Viewed 1890 times
Re: Can’t remove roller bearing from driveshaft spool
That's the "thrust" bearing down there - use a block of wood & press it out.
