26-27 Lower Metal channel door glass
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Wed Jul 22, 2020 2:36 pm
Hi, I finally got door glass for my 27 coupe, and and trying to get it to go up and down. I'm curious what the original channel looked like (mine was gone). Is the reproduction part accurate? it doesn't seem to trap the regulator arm "roller" in it.
Last Name: Humble
Board Member Since: 2006
Re: 26-27 Lower Metal channel door glass
Post by Humblej » Wed Jul 22, 2020 3:52 pm
That does not look right to me. The 26-27 coupe door is the same as the 28-29 model A pickup door. My experience is the model A door parts are correct and better quality than what most of the model T vendors sell.
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Wed Jul 22, 2020 4:55 pm
thanks.
I cut off the angle piece that was spot welded on, and moved it up about 1/8" inch, so it's parallel to the glass, and welded it back on. It seems to work now.
of course I cracked the glass taking the channel off....and it takes a long time for folks to get around to cutting glass, around here, so I'll probably just leave the cracked piece in the car for now.
picture shows modified channel on left, unmodified on on right
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jul 22, 2020 10:07 pm
Jim,
I believe it should work fine since it uses a gravity load and hold. I would just make sure the arm stays parallel as it goes up and down.
Hank
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Wed Jul 22, 2020 10:12 pm
With the new vertical channels, the glass doesn't just drop down...gravity won't hold it in place. And I don't like to rely on gravity to hold things in place over bumpy roads, either.
We'll see how it works with the slight modification I made.
Sure would be nice to see an original part, though.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jul 22, 2020 10:16 pm
Can fabricate you some "L's" if needed to retain the bottom section, just tack weld. I know, some repro stuff is..., crap.
Hank
Last Name: Hatch
Post by Dan Hatch » Fri Jul 24, 2020 7:48 am
Just your thread. I guess you are asking about the piece on the bottom of the glass? There is a stack of nos windows behind my milling machine. I will look and see if one is there. Dan
Last Name: Humble
Post by Humblej » Fri Jul 24, 2020 8:54 am
Why not buy the correct part?
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Fri Jul 24, 2020 9:39 am
I thought I had bought the correct part, it doesn't work. So I made it work.
Call me old fashioned.... :)
Last Name: Hatch
Post by Dan Hatch » Fri Jul 24, 2020 10:21 am
Here is a picture of tag on one NOS window I have. As you can see it fits 23-25 Fordor and coupe. There several windows like it and a few that are different size but no tag.
What size are you looking for? Dan
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Fri Jul 24, 2020 12:11 pm
Thanks. The 27 coupe door windows are about 25.5" wide, and 20" tall. The top is tapered.
jab35
Last Name: Bartsch
Post by jab35 » Fri Jul 24, 2020 7:50 pm
Jim: The window regulator channel on my unmolested, unrestored '26 coupe with original glass appears similar to your modified part. The 'roller' is captive in the channel formed by the glass edge support and the 'L' piece. The 'L' piece is 12.25" long and begins 6" rearward of the forward edge of the glass. I took a poor quality photo that I will send in reply to a message sent to 6 zero 7-five 9 two-four 8 8 two. Best, jb
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Sat Jul 25, 2020 12:46 pm
Thanks for the picture, James. It looks pretty close to what I have, at least the part where the regulator and channel connect, works the same way. Looks like the 26 has a single lower stop in the middle, while the 27 has one at each end of the channel.
So others can see:
jab35
Last Name: Bartsch
Post by jab35 » Sat Jul 25, 2020 2:48 pm
Jim: The single stop and bumper in the pic is pretty beat up, the coupe had a 1943 plate on it when I got it in 1967. I think the T spent its life on gravel roads in central Wisconsin.
