Fordor Roof Dimensions Needed
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Fri Feb 08, 2019 3:14 pm
I’m in process of putting a new wood kit in a 24 Fordor body. Overall it’s coming along well. The old roof wood was in pretty bad shape and not really measurable the way the other parts were. I need the outside width dimensions of the roof. Front back and middle, as that will get me an idea if I’m in the ball park. Thanks!
MichaelA
First Name: Michael
Last Name: Archer
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadsters
Re: Fordor Roof Dimensions Needed
Post by MichaelA » Sat Feb 09, 2019 4:28 pm
Project is coming along great. Hopefully someone has the dimensions you need.
MichaelA
First Name: Michael
Last Name: Archer
Post by MichaelA » Mon Feb 11, 2019 8:10 pm
Is there anyone out there that can get us dimensions?
Last Name: Wrenn
Post by TWrenn » Mon Feb 11, 2019 8:23 pm
Not sure if my 25/'26 roof is the same as a '24? I can measure it tomorrow. Meantime I'll try to determine if there's any significant
size differences. Even tho most of this car is a '25 the body is a 26...the numbers make it what I call an "overlap" car...or it's just a mutt!! Either way I like it!
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Wed Feb 13, 2019 7:58 am
Tim, 25 yes 26 no. Are your door frames steel or wood? Thanks
George Mills
Last Name: Mills
Post by George Mills » Wed Feb 13, 2019 8:18 am
Kenny,
The last time I went 'storage diving' for someone "T" it cost me an exploded kneecap and near 2 years of rehab and it still ain't right...so I unfortunately think twice now about rummaging to get answers for folks.
However...no one seems to be in a place to help you so far and If you do not hear from anyone, give me a shout out and I'll try. I have a never restored April of 25 Fordor (Steel Budd Doors) pristine body tub that is not too buried and I think I just may be able to maneuver without too much gymnastics to get you what you need...I'd have to go gutter to gutter, rather than wood edge to wood edge if that would work for you
Post by John kuehn » Wed Feb 13, 2019 9:39 am
Kenny
You mentioned you have been working on the body wood. Do you have the body pillars in place? They will give you an idea of the width of the top. I have a 24 Coupe I restored and I found that helped me in installing the new top rails in my car. No it’s not a sedan but the idea is the same.
You may already know this but Fordwood makes wood kits for T’s and have online wood structure drawings that are helpful in getting ideas about body wood structure.
I just checked their website and they do have a wood top kit in stock for a 24-25 Fordoor.
They are notoriously slow in making their products as you might already know.
You may prefer to make you own but it can save time when you can buy wood already made.
Whichever way you go in replacing the top wood rails and front and back top pieces you may have to think outside the box when getting the dimensions. I had to do that with my Coupe wood in places. Sort of trial and error I guess.
Hope this helps and good luck.
Post by Steve Jelf » Wed Feb 13, 2019 9:52 am
Does a 1923 Fordor match? If so, I'll get the measurements.
Post by John kuehn » Wed Feb 13, 2019 10:22 am
The 23-25 wood bodies are pretty much the same. The overall outside dimensions are the same but the fit up may be a little different depending who made the wood structure pieces. They all aren’t exactly alike but pretty close. There will be some trial and error in fitting the pieces as you go along.
Post by Steve Jelf » Wed Feb 13, 2019 10:56 am
OK, here's what I found on the 23.
I put the end of the tape even with the edge.
At the front hinges.
Between the doors.
At the rear hinges.
At the rear corner.
Post by Rich Eagle » Wed Feb 13, 2019 11:02 am
Leave it to Steve to come up with a good, logical way to show dimensions. I do so enjoy seeing the close ups of that original Fordor. We loose something when we make them look purdy.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Sat Feb 16, 2019 5:16 am
Steve, thanks. That’s what I needed.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Sat Feb 16, 2019 5:20 am
Here’s the project...
Post by Rich Eagle » Sat Feb 16, 2019 9:30 am
Wow! that brings back some Tudor memories. There aren't many straight pieces there are there?.
Great work.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Sun Feb 17, 2019 2:47 am
Rich, definitely no straight peices. 😁 Not a job for the meek.
Luckily I had decent enough old pieces from the original structure to measure and make the Fordwood kit to the same dinensions.
Yesterday’s progess...
