Mag post short.
Topic author - Posts: 89
- First Name: Michael
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster 1914 Speedster 1925 Touring 1926 roadster pickup
Mag post short.
Has anyone had a mag short out from what I think is band lining and oil touching the post ?My mag failed and after checking the switch and replacing it found this at the contact point For the post. All connections were good and still no voltage. I cleared that goo away and all is ok now.
Re: Mag post short.
Yep, that will surely do that !
- First Name: Bill
Re: Mag post short.
I've had it happen a couple of times over the years. Wire will short it out too- look closely in the mirror
Re: Mag post short.
I was driving at a steady speed and it shut off completely. Restarted on battery fine but didn’t run anymore on mag. I’m just happy it wasn’t the mag that failed.
- First Name: Ronald
- Last Name: Dupree
Re: Mag post short.
Just completed a full restoration on a 1927 touring car. With less than 100 miles on the car the mag quit. The mag post looks like Bill's. I disassembled the post, wiped it out good, and the mag started working again. I could not see any metallic debris inside the post, but it looks like the perfect debris catcher.
Ron Dupree
- First Name: Adam
- Last Name: Doleshal
Re: Mag post short.
It’s in the FORD instruction manuals as one of the first things to check.
- First Name: Victor
- Last Name: Foster
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
- Board Member Since: 2002
Re: Mag post short.
I switched to Kevlar bands and ever since then, no strings shorting out my mag post.
