Screw thread size
Bill Thompson
First Name: Bill
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 Tudor sedan
Screw thread size
Post by Bill Thompson » Thu Aug 06, 2020 10:59 am
I am looking fo 3 screw thread sizes for transmision hogs head. Be did cover, starter mounting, and top access cover.
Thanks in advance
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Screw thread size
Post by R.V.Anderson » Thu Aug 06, 2020 11:13 am
Starter mounting and transmission inspection door screws are both 5/16"-18. In fact, if you have an aluminum cover with worn door threads and you are using a screen filter that fits into the opening, said filter and its two gaskets making original type door bolts in effect too short, starter bolts make an excellent and totally correct appearing substitute.
If you are also looking for the Bendix drive cover screws, they are #14-24.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Aug 06, 2020 11:51 am
Caution, you will not find those #14-24 bendix screws at the hardware store, and something close will not work.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Thu Aug 06, 2020 1:18 pm
I keep a few extra of the special bendix cover screws in my running board tool box just in case I lose one. They're not easily replaceable unless you have a few days to wait to get them from one of the suppliers.
Stephen
