pesty skip found
Chuck Stevens
Topic author - Posts: 32
- First Name: chuck
- Last Name: stevens
- * REQUIRED* Type and Year of Model Ts owned: 1921 roadster
pesty skip found
My 21 roadster has had a skip off and on since I've had it. Yesterday I turned on the ign and hand turned it to each firing point. The garage was dark and I saw a spark in the wrong place, The copper spark plug wire had come loose from the brass end that connects it to the coil. They are soldered originally. A drop of solder and we were back in business. I would have thought the small gap would have no effect on firing the plug. So turn off your lights and see what you see. It made my day, Chuck.
Re: pesty skip found
That’s good that you found it!
The simple fix things are usually the hardest to find sometimes. I’ll bet that’s happened to more than few T’s.
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
My wife sez I do some of my best work in the dark!!!!!
frontyboy
frontyboy
