Thread chasing die for original tire valve stems
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Wed Jul 01, 2020 3:10 pm
I have finally gotten a quote for making these very-special-thread (13/32" x 28) dies. One die is $147 but we can get them for less than half of that --$70 each-- if we order at least 6. The price doesn't change after that. This round, adjustable HSS die would be for chasing damaged threads on original brass valve stems, although it will be able to cut new threads once it's re-adjusted for that.
Perhaps a few chapters would want one for their tool cribs??
We could also get taps made in the same size, for chasing threads in original stem hardware, if another 6 guys would want one of those. Price would be in the same ballpark.
So--any interest?
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Re: Thread chasing die for original tire valve stems
Post by pre15dale » Wed Jul 01, 2020 8:59 pm
I Wil take one. Dale Kemmerer
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Wed Jul 01, 2020 10:53 pm
I'll take one as well
Post by Steve Jelf » Wed Jul 01, 2020 11:34 pm
I gather that would be for the #777 stems, and not the more common #724 and #725 stems. Is that right?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Jul 02, 2020 1:42 am
RV- check your PMs. Dan
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Fri Jul 03, 2020 1:05 am
I'd like one.
Last Name: Strange
Post by CudaMan » Fri Jul 03, 2020 7:57 am
Hi R.V., please put me down for one, thanks! :)
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Jul 03, 2020 11:28 am
OK; we have our 6, so the lower price has kicked in. The die maker's Engineering department is closed until Monday; I will confirm some important details of the new die's construction with them then, so I guess Tuesday July 7 will be the cutoff for reserving one so we can get these under way. Thanks everybody!
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Fri Jul 03, 2020 1:02 pm
I will take one also, Bob
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Fri Jul 03, 2020 1:39 pm
Hi R. ., I'll take one also.
Thanks,
Keith
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Post by Philip Lawrence » Fri Jul 03, 2020 6:59 pm
R.V., If it's not to late to jump on the band wagon I would like to have one also.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Jul 03, 2020 8:47 pm
Nope; not too late. After Tuesday it will be, at least for this go 'round.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Jul 06, 2020 11:54 am
OK; their Engineering dept. has confirmed that these will be specially-built dies suitable for thread chasing use on original sized, two-flat-side Schrader 777 & 888, Dill, Firestone, or TR (Tire & Rim Mfr.) valve stems in the size specified by Ford, which is 13/32" x 28 tpi. This size was used exclusively by Ford after 1920; until then they were used along with a larger size (15/32" x 26) which was specified for use on 30 x 3-1/2" tubes but was discontinued after 1920.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Tue Jul 14, 2020 5:02 pm
Update: These are underway. A total of 9 dies have been spoken for; that will comprise the run. The die maker is using an original stem as a template to ensure that the finished dies will perform as they should. They should be ready in about 10 days-2 weeks.
Last Name: Strange
Post by CudaMan » Tue Jul 14, 2020 5:28 pm
Great! Let us know when, how much, and by what method you want to be paid, thanks again!
RichardW
Last Name: Williamson
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by RichardW » Tue Jul 14, 2020 9:55 pm
If there is one available I would like to buy one
Richard Williamson
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Tue Jul 14, 2020 10:09 pm
Please put me down for one!
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Wed Jul 15, 2020 10:49 am
OK, Richard and Steve; it's after the deadline but I contacted the die maker and asked if they'd accept two more. Looks like it won't be a problem because they are building a prototype for testing before going on to the full run. But if anyone else wants one, better let me know today.
Post by Original Smith » Wed Jul 15, 2020 11:48 am
It doesn't matter the number on the valve stem, as long as the thread is the same! The only thing changing is the length of the stem.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Aug 03, 2020 6:09 pm
OK everyone; the new dies have arrived and I will be sending them off to their new owners tomorrow. I have tried mine out on 5 different original stems and I'm very happy with how well it works. The die is fully adjustable and can cut new threads as well as chase old ones.
Thanks everybody!!
Post by Original Smith » Tue Aug 04, 2020 11:39 am
This is for those who really care about authentic parts. The early round serrated rim nuts are now being made by Dan McEachern in Alameda. He sells them for $20 each. He went to a lot of work to make them for us.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Aug 04, 2020 12:39 pm
Thanks Larry! And of course RV for making the dies. Here is a picture of the early rim nut.
Last Name: Strange
Post by CudaMan » Tue Aug 04, 2020 1:15 pm
Neat rim nuts! Are they solid on the bottom, or do they have a pocket for a leather washer like the hex ones have?
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Aug 04, 2020 1:21 pm
These are exactly like the originals in every feature. Larry has even blessed them as being correct!
Post by Original Smith » Tue Aug 04, 2020 2:40 pm
Thanks for the kind words Dan. Dan doesn't include the leather washer. As I recall, I had to find an 11/16" punch to make them, and used a 3/8" for the center. I don't see how anyone that is familiar with Dan's work would even think they would be solid on the bottom!
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Tue Aug 04, 2020 4:36 pm
I have a great source for the leather washers; top quality and very reasonably priced. Stay tuned...
All the dies have been shipped; went out today so if you ordered one be looking to get yours in a few days to a week.
Last Name: Strange
Post by CudaMan » Sat Aug 08, 2020 1:59 pm
I received my die from R.V. today and immediately put it to work cleaning up the threads on a couple of Schrader stems. It works great! Since it's adjustable, you can adjust it to just lightly dress the bad spots or tighten it up for a more aggressive cut. :)
Post by Original Smith » Sun Aug 09, 2020 9:43 am
I received mine yesterday. Haven't had a chance to try it yet. R.V. makes the coolest stuff! Thanks Randall.
KeithG
First Name: Keith
Post by KeithG » Sun Aug 09, 2020 3:36 pm
Mine came on Friday & it works great!!! Thanks very much, R.V.
Keith
