Coil Box found
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Coil Box found
Post by Unprr » Thu Aug 06, 2020 8:21 pm
I found a coil box at an antique store and took the attached photos. My question is this, would this be used in a Model T? The coils look nothing like the ones I have in my T.
George
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Coil Box found
Post by R.V.Anderson » Thu Aug 06, 2020 8:34 pm
This Kingston box and coils would have been used originally in a 1912 T.
Retro54
First Name: Andrew
Last Name: Blaydon
Re: Coil Box found
Post by Retro54 » Thu Aug 06, 2020 9:28 pm
Great find!
AndreFordT
First Name: Andre
Last Name: Valkenaers
* REQUIRED* Type and Year of Model Ts owned: 1926 ; 1922 ; 1915.
Re: Coil Box found
Post by AndreFordT » Fri Aug 07, 2020 1:00 am
As said before, your coil box was used in the early model T's.
The coils in the box are all missing the points and are all bridged with a wire.
To make the ignion work, you need to add a master coil to the ignition loop.
Those early coils were (and still are) hard to adjust correctly.
The use of a mastercoil makes the ignition timing even for all four coils.
I will try to find some photo's of the set up of the ignition of my 1922 woody with a master coil that I run this way since 2012.
The master coil is K&W and the coils are usual Ford coil with the bridge on the points.
I made this setup only to try to understand the working and the use of the master coil.
In 2012 some one give me the advice to take a set of regular coils in the car because the master coil will break down. Now 8 years and a few thousand miles later it is still working. The spare coils are still in the car but they helped others to finish the drives on four cilinders.
Andre
Belgium
AndreFordT
First Name: Andre
Re: Coil Box found
Post by AndreFordT » Fri Aug 07, 2020 1:11 am
This is how your coils should look like.
https://www.modeltford.com/item/4238.aspx
Andre
Belgium
TonyB
First Name: Tony
Last Name: Bowker
Re: Coil Box found
Post by TonyB » Mon Aug 10, 2020 12:13 am
Those coils look like the Kingston coils used in 1909-10 model T
Tony Bowker
La Mesa, California
Duey_C
First Name: Duane
Last Name: Cooley
Re: Coil Box found
Post by Duey_C » Mon Aug 10, 2020 12:55 am
Oh my. Neat find. :)
