Gouged pinion gear?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Gouged pinion gear?
Post by ivaldes1 » Wed Aug 05, 2020 12:26 am
I have a pinion gear with one tooth gouge on it pictured. I wonder how it happened? I don't actually need it because I am changing to a higher ratio of 3:1 but I would rather not just throw it away. It is otherwise good. Other than put it in the box of bad parts what can I do with it?
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Re: Gouged pinion gear?
Post by Stephen_heatherly » Wed Aug 05, 2020 8:06 am
Keep it as a conversation piece or throw it away. It's not good for anything anymore.
Stephen
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Wed Aug 05, 2020 9:42 am
Paperweight? Maybe a projectile for a BIG slingshot? Definitely not in a differential any more...
That pinion has shuffled off its mortal coil, and should be permanently retired. If it was a one-off only one in existence pinion, I'd consider using it as a pattern to make a new one... ABSOLUTELY worst case it could be welded, machined, heat treated, hardened, and maybe put back into light duty service, knowing you put a grenade in your rear end and expecting it to come back apart and cause a catastrophic failure of your differential.
Post by Jerry VanOoteghem » Thu Aug 06, 2020 6:37 pm
No, it really isn't. Keep it as a conversation piece?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Thu Aug 06, 2020 6:52 pm
I've decided to wear it to church.
Post by Jerry VanOoteghem » Thu Aug 06, 2020 9:10 pm
An excellent idea! :)
GrandpaFord
First Name: Neil
Last Name: Kaminar
Post by GrandpaFord » Fri Aug 07, 2020 8:31 am
The highest stress on a gear face is not at the surface but below the surface. After many cycles the gear will fail by spalling. The number of cycles it takes depends on the steel and the force. More force means shorter time. Once a spalling failure occurs on one face the rest are close behind. Better to replace the gear.
Post by DanTreace » Fri Aug 07, 2020 8:54 am
Ignacio
Your pinion gear is rather nicer than this one :)
Could only guess how noisy it ran....or if the owner of that T ever added lube to the axle :shock:
IMG_6455 (500x375).jpg (83.4 KiB) Viewed 5948 times
Post by John kuehn » Fri Aug 07, 2020 9:37 am
WOW Dan!
That has to be one for the record books!
Using that gear as a guide for how long they will run makes Ignacios gear look
good for a lot more miles down the road.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Aug 07, 2020 10:00 am
A little JB weld and both those pinion gears are good as new !! :lol:
My 13 tooth had a missing tooth that developed last fall....it's in the scrap bucket.
Excessive side shim wear and a loose pinion nut were my assumption of the cause.
New spool FP bearings and reshimmed and all good so far, shifting is much smoother too. :D
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Aug 11, 2020 12:17 pm
Ignacio, does that pinion gear have Ford script on it? Ford, in the Service Bulletins that it sent out to dealers and repair stations, warned against customer's and mechanic's use of cheaper, inferior, non-Ford parts made of cheaper metals. If it has Ford script on it, Ford wouldn't wanted the public to know that one of HIS parts had failed. He would have wanted that one, BACK.
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Post by GEmering » Tue Aug 11, 2020 1:33 pm
Just a curiosity question from a wannabe mechanic or maybe closer to a non-mechanic pretending to be one...
If you replace a worn pinion gear is the ring gear normally replaced too?
Would a brand new pinion gear and good but somewhat used ring gear not mesh as well as both new?
I am in the process of rebuilding the rear end on my '24 touring so I guess this is a good time to ask.
Thanks for the learning.
Gene
Gene Emering
Newton, New Jersey
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Tue Aug 11, 2020 2:05 pm
As a hat? A ring? A necklace?
Please elaborate.
1924 Touring
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Wed Aug 12, 2020 12:06 am
It would be immodest for me to divulge.
Please elaborate.
