Picture of crown gears and pinions with different ratios.
Topic author - Posts: 958
- First Name: Ignacio
- Last Name: Valdes
Just for your information, the picture shows a 10 tooth pinion and a 40 tooth crown gear, a 11 tooth pinion and 40 tooth crown gear, and finally a 13 tooth pinion and 39 tooth crown gear. The 13:39 is going into hay wagon to speedster project.
