Gouged pinion gear?
ivaldes1
Topic author - Posts: 960
- First Name: Ignacio
- Last Name: Valdes
Gouged pinion gear?
I have a pinion gear with one tooth gouge on it pictured. I wonder how it happened? I don't actually need it because I am changing to a higher ratio of 3:1 but I would rather not just throw it away. It is otherwise good. Other than put it in the box of bad parts what can I do with it?
Stephen_heatherly
- First Name: Stephen
- Last Name: Heatherly
Re: Gouged pinion gear?
Keep it as a conversation piece or throw it away. It's not good for anything anymore.
Stephen
Stephen
Susanne
- First Name: Susanne
- Last Name: Rohner
Paperweight? Maybe a projectile for a BIG slingshot? Definitely not in a differential any more...
That pinion has shuffled off its mortal coil, and should be permanently retired. If it was a one-off only one in existence pinion, I'd consider using it as a pattern to make a new one... ABSOLUTELY worst case it could be welded, machined, heat treated, hardened, and maybe put back into light duty service, knowing you put a grenade in your rear end and expecting it to come back apart and cause a catastrophic failure of your differential.
ivaldes1
- Last Name: Valdes
I've decided to wear it to church.
GrandpaFord
- First Name: Neil
- Last Name: Kaminar
The highest stress on a gear face is not at the surface but below the surface. After many cycles the gear will fail by spalling. The number of cycles it takes depends on the steel and the force. More force means shorter time. Once a spalling failure occurs on one face the rest are close behind. Better to replace the gear.
Ignacio
Your pinion gear is rather nicer than this one
Could only guess how noisy it ran....or if the owner of that T ever added lube to the axle
WOW Dan!
That has to be one for the record books!
Using that gear as a guide for how long they will run makes Ignacios gear look
good for a lot more miles down the road.
Ruxstel24
- Last Name: Hanlon
A little JB weld and both those pinion gears are good as new !!
My 13 tooth had a missing tooth that developed last fall....it's in the scrap bucket.
Excessive side shim wear and a loose pinion nut were my assumption of the cause.
New spool FP bearings and reshimmed and all good so far, shifting is much smoother too.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Ignacio, does that pinion gear have Ford script on it? Ford, in the Service Bulletins that it sent out to dealers and repair stations, warned against customer's and mechanic's use of cheaper, inferior, non-Ford parts made of cheaper metals. If it has Ford script on it, Ford wouldn't wanted the public to know that one of HIS parts had failed. He would have wanted that one, BACK.
GEmering
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Just a curiosity question from a wannabe mechanic or maybe closer to a non-mechanic pretending to be one...
If you replace a worn pinion gear is the ring gear normally replaced too?
Would a brand new pinion gear and good but somewhat used ring gear not mesh as well as both new?
I am in the process of rebuilding the rear end on my '24 touring so I guess this is a good time to ask.
Thanks for the learning.
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
RustyFords
- First Name: Don
- Last Name: Allen
ivaldes1
- Last Name: Valdes
It would be immodest for me to divulge.
