Different....
Newtexaz
Topic author - Posts: 47
- First Name: Randy
- Last Name: Clemens
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Roadster, 1927 Fordor
Different....
Does anyone happen to know what the story is with this? If there is one.....
thom
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
Re: Different....
The guy needs to stick to building killer bicycles. He has built a fantastic replica penny-farthing and a forkless bike that is amazing to see.
https://youtu.be/7qiR7E3dpjk
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Re: Different....
Me thinks it is a Photoshop creation. I have seen the same one in red elsewhere.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Susanne
- First Name: Susanne
- Last Name: Rohner
Re: Different....
No, it's real... the guy takes old european iron and modifies it. Kind of like a chopper builder. He uses VW's and old Citrôens and Trabi's and whatever else he can grab. This is his second "creation" based around a T - the first (which was red) is a touring body. (You can see the vents for the VW motor in the rear side panels of that one)...
Google "Chopper Olli VW"...
Susanne
- Last Name: Rohner
Re: Different....
Yep, that's the one. Wonder how well that things stops on 2 wheel brakes and 30x3 1/2's - it looks like a fairly heavy beast...
Considering that VW Transporters are about as collectable as T's nowadays, he has the rare ability to piss off 2 different groups of vehicle collectors at the same time!
Actually, I think his stuff is impractical as hell... but amazing, in a sort of Orange County Choppers sort of way.
Re: Different....
The question would be, does he sell it and what would they do with it.
- Last Name: House
Re: Different....
...and his brass horn is upside down and the driver can’t reach the carbide generator. What a waste..
Re: Different....
I remember T Buckets at Rod Shows with chrome plated, dual oil tail lights mounted upside down.
.....in the eye of the beholder.
ModelT46
- First Name: Darel
- Last Name: Leipold
Re: Different....
Th horn is not upside down. The bell is up as it should be.
- Last Name: House
Re: Different....
So....Darel; when the “bell up” horn gets filled with rainwater, does it have to be removed and emptied ?
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: Different....
Both of you are right, in a way.
Tripple twist horns are bell up.
Latter horns, like on 13 and 14's are bell down.
Tim Rogers
- Last Name: Rogers
- Board Member Since: 2013
Re: Different....
Sorry, but these don't appear to be real. Has anyone seen these in person?
GrandpaFord
- First Name: Neil
- Last Name: Kaminar
Re: Different....
Photoshop. Good job though.
ModelT46
- First Name: Darel
Re: Different....
The bell is up as original. Go to the original photos of brass Fords.
BE_ZERO_BE
- First Name: BOB
Re: Different....
No "T Style" door fits that good - custom or otherwise.
Be_Zero_Be
Be_Zero_Be
Walter Higgins
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Re: Different....
In the comments of this blog someone asked if these are real and the owner of the blog states that these are "CGI" (computer generated imagry):
http://justacarguy.blogspot.com/2018/09 ... again.html
thom
- First Name: Tommy
- Last Name: Coffey
Re: Different....
If it had been the guy I thought, from Finland, here's a video of his home-built penny farthing bicycle.
https://youtu.be/OptGmDkEwJs
I have one with a 52" front wheel.
GrandpaFord
- First Name: Neil
Re: Different....
Another clue: The rear wheels are cambered in quite a lot like the ones on the back of a VW bus. The T axle would have the wheels straight up and down.
BE_ZERO_BE
- First Name: BOB
Re: Different....
Here is another CGI Car.
Be_Zero_Be
Be_Zero_Be
- First Name: Keith
- Last Name: Townsend
Re: Different....
I would think that a hybrid of a WV bus and a Model T would be the worst thing to be behind if you were you were in a hurry...
Newtexaz
- First Name: Randy
Re: Different....
Thanks everyone. I saw quite a few issues with the red one. If the black one is CG they did a much better job of that one. These days, sometimes you have to study a photo real close......
