I have read the “1913-14 Gaslight” thread with great interest.
I have a carbide tank on my 1913 touring but nothing else.
I am going to try the McMaster-Carr red hose for now, but can someone recommend a source for the correct pipe and clamps?
Also, is there a good diagram or photographs that show where everything runs?
I have a 1913 Touring
Plumbing Carbide Tank 1913 Touring
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Gene
Re: Plumbing Carbide Tank 1913 Touring
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Kenneth
- Last Name: Parker
Gene,
Covered in the link you have...
There is only the one clamp and when I checked my car it was still in place so I used it.
The only other piece is the brass "rear gas line" which is 44" long.
One of the reasons Ford used small clamps was to avoid introducing air (oxygen) into the acetylene lines before the lit burners.
That is why "loose" lava burner heads can introduce air and create a popping noise. A little contact cement fixes that.
Below are radiators on the assembly line 1913/14. You can see the small clamps if you look carefully.
I can't see the short 5-6" hose to the rear gas line since it would go straight down,
but all hoses attached to the radiator are in place prior to sliding down to the assembly line.
Bottom pic is definitely a line up of '13s, based on the spade mount for the Carriage lamps. Also answers any questions/doubts as to exactly how the horn should be: Black! with brass screen, and of course the bell mounted "down". Nice pic!
- Last Name: DeLong
Would the moving line the cars are on date them?? Bud.
- Last Name: Parker
Gene,
I agree with you on the red for the acetylene gas hose.
If you look at the last photo I posted, the gas line hoses appear
much like the radiator hoses which are red.
Certainly not cream, or white, like the tires in that photo.
Do you have your Mangin mirrors?
Ken in Texas
Ken in Texas
