You Will Never Know What You May Find in a Model T Engine
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Aug 20, 2020 8:16 pm
This was a big surprise, Mr Rick Rice ask us to get a project started for him as it had a few issues. After doing an assessment and inspection was not expecting to see this...., A Chevy Crankshaft and Rods, with all the goodies stuffed inside. Someone really spent some bucks on this, you can even see opposite grinds on the throws from bob weighting each one, stove baked block inside, the ports opened up in a very clean method, just..., "WOW".
I told the two young men, "This is old man eye candy"!
Re: You Will Never Know What You May Find in a Model T Engine
Post by RajoRacer » Thu Aug 20, 2020 9:04 pm
That's alot better than what I found in this one !!!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Aug 20, 2020 9:10 pm
Some engineers do not clean up after partying! LOL! I blew a whole nest out of an exhaust pipe one time, that was funny as all get out when it hit the wall!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Aug 20, 2020 9:32 pm
I know that engineer. He has partied in my shop.
Daniel828
First Name: Daniel
Last Name: Brennan
* REQUIRED* Type and Year of Model Ts owned: 1
Post by Daniel828 » Thu Aug 20, 2020 9:50 pm
that engine looks really clean to have the engineers move in so quickly? no?
Last Name: Hjortnaes
Post by DHort » Fri Aug 21, 2020 2:52 am
Those were MIT engineers. You can tell from the domes. Probably celebrating a win over Stanford.
Post by RajoRacer » Fri Aug 21, 2020 11:02 am
That was a freshly rebuilt engine that sat a couple years in his garage - he wanted me to start it for him but I told him "not unless you agree for me to tear it down" - cleaned everything, installed new rings & re-lubed it and it ran perfect !
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Fri Aug 21, 2020 11:17 am
Those engineers have had whole conventions in my barn in the past. I've had to call in the cops.
1924 Touring
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Aug 21, 2020 11:40 am
Hi Hank,
I'm close to send you my engine to you if they open the border soon. Not able to fix the overheat on my rebuild engine... The guy who made it pass away last year... He was well estimated to making good job. Timing is perfect, I have some free start, Intake is perfect no leak and the Radiator is perfect as you know... But still have this overheat after 15 minutes...
Super Mario Bross ;)
1911 Touring
1914 Speedster
Novice
First Name: Jim
Last Name: Davis
Rebuilt Engine Over Heating
Post by Novice » Fri Aug 21, 2020 1:38 pm
Mario. I am no expert. But did You check to see if Your car has a thermostat. 15 minutes is about the time it takes a T engine to warm up and if a thermostat was added in rebuild it could be stuck. sounds like a coolant flow restriction since with correct timing the engine should not be producing a lot of excess heat and the free starts indicate engine is not too tight. a good radiator should be dissipating the heat. Check the engine head temp along with the radiator top tank and the radiator lower outlet going to the engine and see what the differential temp is. I use a cheap harbor freight infrared gun type thermometer. the lower hose inlet should normally be about 40 degrees ? or more lower than top tank with engine running.
"It's the little bugs that eat Your lunch" Good Luck.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Fri Aug 21, 2020 9:17 pm
Boy are those Chevrolet crank shafts tough.
Really neat photos!
BillyBobsSpeedShop
First Name: Bill
Last Name: Webb
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster, 1927 Roadster
Post by BillyBobsSpeedShop » Fri Aug 21, 2020 9:46 pm
Cool find!
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Sat Aug 22, 2020 10:17 am
Hi Jim,
Thank you for your advice. I have a Thermostat and a brand new radiator too. After 15 minutes is bowling a lot.
Maybe I will try to buy a cheap harbor freight infrared gun type thermometer to see what happen in different place of the engine.
1911 Touring
1914 Speedster
