Replacement air filter element suggestions?
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Sat Aug 22, 2020 12:04 pm
I had the bright idea to rinse the old filter oil from the foam element using lacquer thinner. That seemed to work, but gone with the old oil was the original size of the filter and virtually all integrity of shape. Oops.
Lang's catalogs the replacement elements at US$14.75US. I like Langs a lot but after USPS shipping and currency exchange that's more like Cdn$30 and at least weeks away.
I'm hoping forumeers can suggest perhaps an alternate source, reasonable substitute, or some other filter type that could be adapted. One of the things I like about this filter setup is the inconspicuous appearance — the speedster has no hood sides and anything noticeably modern makes me cringe. On the other hand, this is a fresh engine and there will be much gravel in our near future, so maybe I could live with modern and effective until we get home... T
Re: Replacement air filter element suggestions?
Post by Steve Jelf » Sat Aug 22, 2020 12:33 pm
Edmonton is mighty big town. I expect you could find some foam scraps at an upholstery shop or mattress factory. Or if you can stand the appearance you could install a generic filter like the ones I buy at O'Reilly for about $20. I think the sink drain and flange cost perhaps another $10.
25 roadster john
Last Name: Pawlowski
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by 25 roadster john » Sat Aug 22, 2020 5:17 pm
Interesting set up Steve. Any chance you have information on that filter housing assembly? Also how is the flange attached to the carburetor.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Aug 22, 2020 7:17 pm
My variant
The filter I bought at Canadian Tire. The tubing is a 1-1/4” sink trap. The carb adapter and the filter mounting plate I made. Has LOTS of filter capacity for country roads!!
NO it doesn’t make the “invisible” requirement!
Post by TRDxB2 » Sat Aug 22, 2020 8:23 pm
Take it to a motorcycle shop - likely they have something that will fit or replace. The filter wasn't designed for a Model T - just a universal product that fit the carburetor. Remember you only have 22hp They may even have something for a ride on lawn mower or tractor shop
rondupree
First Name: Ronald
Last Name: Dupree
Post by rondupree » Sun Aug 23, 2020 10:26 am
One possibility
Ron Dupree
Ron Dupree
Post by Steve Jelf » Sun Aug 23, 2020 11:14 am
John, I don't remember the brand. I just went into the local O'reilly store and asked for a generic air filter and that's what they had. It was around $20.
At first I attached it with the standard Ford repair kit (baling wire).
Later I made some clamps to hold it in place.
25 roadster john
Post by 25 roadster john » Sun Aug 23, 2020 1:31 pm
Thanks Steve, I'll check out Advance, Auto zone and NAPA. I got a laugh about the bailing wire. Years ago bailing wire and duct tape kept our buses on the road.
Once I saw a bus going down 5th Avenue with a Masonite advertising sign , secured with duct taped, in place of a side panel. I'm sure that didn't go over well.
But I'm sure the public didn't mind just happy to see their ride.
jsaylor
Last Name: Saylor
Post by jsaylor » Sun Aug 23, 2020 3:49 pm
Here is the link to the UNI website. They are listed by diameters and length. Also a tab to cleaning.
https://unifilter.com/online-catalog/cl ... r-filters/
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Mon Aug 24, 2020 8:53 am
Check out the K&N Filters website: https://www.knfilters.com/, and see if they have something you could use. If they have a product that would work, just contact your local auto parts stores to see who has it or can get it.
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Wed Aug 26, 2020 2:44 pm
I'm late getting back to this thread, but thanks to all who responded.
The immediate need has passed — after the lacquer thinner evaporated, my filter element returned to its original size and shape. Said element is now re-oiled and back in place.
On the less-urgent hunt now for unobtrusive replacement options...
