1911 tail lamp bracket
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Sun Aug 23, 2020 11:31 am
What bolts or screws are used to attach the blade style tail lamp bracket to the body on a 1911 touring? Thanks, Art
John Haynes
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
Re: 1911 tail lamp bracket
Post by John Haynes » Mon Aug 24, 2020 5:48 pm
I believe they are carriage bolts with square nuts. I have attached photos of my early 1912 Touring which should be the same as the 1911 touring.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Mon Aug 24, 2020 6:15 pm
Thank you, that helps. Art
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Tue Aug 25, 2020 9:34 pm
The original tail light bracket on my 12 has square hoses and the carriage bolt with the square goes from the outside and the square nuts are on the back side out of sight the repro brackets have a round hole.
shadetree
First Name: ward
Last Name: sherwood
Post by shadetree » Wed Aug 26, 2020 9:31 am
A picture of an "11 I used to have. The square nuts were on the outside. I don't know if this is factory correct or not.
Post by Original Smith » Wed Aug 26, 2020 9:56 am
The 1913-14 roadster brackets are the same. The carriage bolts are a special Ford design. I had to use step bolts for mine, and I couldn't find originals that were for sale. You can't see them anyway, but I like original parts.
