Model T Engine Stand
Dennis Fleming
Last Name: Fleming
* REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
Post by Dennis Fleming » Sun Aug 23, 2020 5:15 pm
I posted on the Model T Ford Club of Facebook a while back about an engine stand I built from a Model T rear differential. Things I have found out. I can rotate the engine and transmission w/ pan 360 degrees. I can not rotate all the way around with the hogshead or the crank handle in place. The weight of the hogshead will not allow my braking system (friction brake by clamping the differential to the housing via a through bolt) hold the engine unit horizontal. But found a solution by inserting a flat screw driver between the pinion and ring gear. Holds fine by brake when the hogshead is remove. Found rotating vertical great to drain old nasty motor oil from the pan. Infinite positions are useful for disassembly. So far so good!!
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Re: Model T Engine Stand
Post by tom_strickling » Sun Aug 23, 2020 6:00 pm
Pretty slick!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Aug 23, 2020 6:02 pm
Pretty Awesome Dennis! Love old parts being recycled.
Post by Rich Eagle » Sun Aug 23, 2020 6:07 pm
How appropriate.
Post by Norman Kling » Sun Aug 23, 2020 6:08 pm
Very interesting. I can see that you are quite creative! Looks like it would work very well.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sun Aug 23, 2020 6:34 pm
Nice work Dennis!
NU2theT
Last Name: Wendt
Post by NU2theT » Wed Aug 26, 2020 7:43 pm
Thanks for posting those pictures Dennis, looking @ some T parts this week and several rear axles to harvest.
What is your dimension from the floor to the center of that differential housing and is the plate you used 1/4" like the engine stand adapter?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Wed Aug 26, 2020 10:02 pm
I find this tool to be altogether pleasing, elegant, and entirely fitting for the purpose. Salute!
