cooling system rust inhibitor
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Wed Aug 26, 2020 9:35 pm
Need a recommendation for a good cooling system rust inhibitor. One of my Ts has turned its cooling water red.
mgarrett
Last Name: Garrett
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster, 1924 Touring
Re: cooling system rust inhibitor
Post by mgarrett » Wed Aug 26, 2020 9:53 pm
Water Wetter, Purple Ice, 40 Below are available at most auto supply stores. Be sure to use the proper amount based on the volume of water your cooling system holds.
Post by RajoRacer » Wed Aug 26, 2020 10:17 pm
I recently used a product named "Thermocure" in a friend's Model A that had sat quite some time - drained the crud out added 1 gal. of water, a quart of the additive then topped off the radiator - drove the car approx. 200 miles, drained it off, flushed 3 times until running clear then added distilled water & 1 gal. coolant - good to go !
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Thu Aug 27, 2020 12:34 am
No-rosion is good and their website has technical articles. Use reverse-osmosis (RO) purified water rather than distilled, unless you are using at least 50% coolant.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Thu Aug 27, 2020 12:37 am
Proper mix of your choice of Conventional Antifreeze should provide adequate rust prevention after you get it cleaned out.
Greg suggestion is a good one rather than Distilled water.
1912 Torpedo Roadster
Last Name: Patrick
Post by jiminbartow » Thu Aug 27, 2020 12:38 am
How about a water soluble lubricant used in machine shops to lubricate and prevent over heating of turning drill bit points, or a water soluble water pump lubricant? Rust will not form in oily water. Jim Patrick
Post by TRDxB2 » Thu Aug 27, 2020 11:40 am
If you have RO system on your kitchen tap - its filter may provide all the reverse-osmosis (RO) purified water needed. Check your filter for details. If you don't, some bottled water is RO purified BUT some add back minerals to improve taste. In checking Aquafina seems to be un-enhanced with minerals removed from the final product - cost is minimal as well https://www.aquafina.com/pdf/bottledWat ... ion_en.pdf
If your looking to clean out radiator here is a simple process https://barsleaks.com/radiator/how-ofte ... -radiator/ and follow-up.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Thu Aug 27, 2020 5:02 pm
Thanks to all. I picked up some w wetter and will use it till I put antifreze back in.
John Illinois
Last Name: Burgett
Post by John Illinois » Thu Aug 27, 2020 5:29 pm
I used water wetter and water in my Model A for a summer. It did not protect against rust.
The directions say use 15% anti freeze for street use. If I did it again I would add some anti freeze.
John
Post by Jerry VanOoteghem » Fri Aug 28, 2020 7:30 am
Prestone...
