wood seat frame
JoeG48
First Name: Joe
Last Name: Gallagher
wood seat frame
Post by JoeG48 » Sat Aug 29, 2020 1:56 pm
Hello
Does anyone know the center distance of the two 5/8 holes for adjusting seat position, in the wood seat frame (frame seat spring sits on) for a 1927 Coupe?
In addition, does anyone know if the seat spring is fastened to the wood frame, if so how?
Thank you
Joe
joeg48@hotmail.com
jab35
Last Name: Bartsch
Re: wood seat frame
Post by jab35 » Sat Aug 29, 2020 3:18 pm
Joe: 24" center to center on My '26 coupe. I made the holes slightly over 5/8, but I'd wait to drill those til you have the seat riser, just in case.
There are sheet metal tabs folded over the bottom spring frame along the front and back of the spring that wood screw to the forward and rear rails of the wood base. I think there are 3 tabs, 2 near the corner and one near center of the spring, front and rear. Have fun, jb
JoeG48
First Name: Joe
Re: wood seat frame
Post by JoeG48 » Sat Aug 29, 2020 4:21 pm
Thanks for the info James .... But I am looking for the measurement from the front edge of the wood frame to the center of the first hole and also the center to center dimension from the first hole to the hole behind it (going to the rear of the car ) Sorry for the mix up ...Joe
jab35
Last Name: Bartsch
Re: wood seat frame
Post by jab35 » Sat Aug 29, 2020 8:04 pm
Joe: I sent you a message, will send info tomorrow 8/30, best, jb
