Does this look fine
Wwbbim
First Name: Jace
Last Name: Jensen
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Does this look fine
Post by Wwbbim » Mon Aug 31, 2020 9:28 pm
Got done safety wiring my ruckstell and it’s now time to start painting the cases and putting it back together. I got the differential together but I just wanted to make sure I didn’t put anything together wrong or such Thanks!
Joe Bell
First Name: Joe
Last Name: Bell
Re: Does this look fine
Post by Joe Bell » Mon Aug 31, 2020 10:02 pm
Nice safety wire, you must be an aircraft mechanic also?
Wwbbim
First Name: Jace
Last Name: Jensen
Post by Wwbbim » Mon Aug 31, 2020 10:09 pm
Nope my dad helped me through. He’s the aircraft mechanic and that’s where I’m learning how to do a lot of this stuff.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Tue Sep 01, 2020 12:13 am
Those springy doodads look in good shape.
Wwbbim
First Name: Jace
Last Name: Jensen
Post by Wwbbim » Tue Sep 01, 2020 12:16 am
They came out of the cases fun and all seems to turn well while cases are attached to the differential also. And yes the springy thingsmajigs are in pretty good condition just like most of the parts.
brendan.hoban
First Name: Brendan
Last Name: Hoban
* REQUIRED* Type and Year of Model Ts owned: 22 Touring
Post by brendan.hoban » Tue Sep 01, 2020 5:55 am
The "springy doodads" are on the wrong side, when going forwards they should bring the differential grease towards the centre, not outwards onto the brake drums.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Tue Sep 01, 2020 10:12 am
Good catch, Brendan. The small end of the springs goes toward the center so the large end can hang down, touching the axle tube, and (hopefully) by the spiral action picking up the excess oil and moving it towards the center.
Dan B
Last Name: Blaydon
Post by Dan B » Tue Sep 01, 2020 10:32 am
As far as I know, those woodsworth grease springs are no longer being made. Is the prevailing opinion still that it’s a good idea to put them in even with the modern seals that are available?
brendan.hoban
First Name: Brendan
Last Name: Hoban
Post by brendan.hoban » Wed Sep 02, 2020 5:43 am
Dan,
I installed the modern seals AND the spiral springs, just insurance I suppose.
Now, 3000kms later, the rear end, outer ends are dry.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Thu Sep 03, 2020 10:27 am
I can’t see the detail on the wiring of the ten bolts for the ring gear, but Lee Pierce taught me to wire them in pairs. So bolts are wired in pairs. The three bolts on the differential can be split pinned but those using three studs should be wired together.
One old timers trick if the hub or axle taper is a little worn. Move the gear on the end of the axle shaft and widen the groove for the keyway towards the center. Then reassemble but add another fiber washer between the two shafts. Works great and saves buying new axle shafts or those nasty shims.
Tony Bowker
La Mesa, California
