Please Let Me Know If You Are Using This...
Tim Rogers
Topic author - Posts: 387
- Last Name: Rogers
...mirror on a 23, 24 or 25 Runabout windshield stanchion. Is it solid with minimal vibration ?
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
Re: Please Let Me Know If You Are Using This...
I have one on my 27 roadster and love it. Very solid, very little vibration. When looking in the mirror, if one car is following you, you see one car, not 5 because of vibration!
Tim Rogers
- Last Name: Rogers
Thanks Tom. I'm wondering if it would fit the 23 stanchion firmly as well.
Bill Bohlen in La Habra, California makes those.
Dan_Jensen
- First Name: Daniel
- Last Name: Jensen
My car came with these mirror brackets that screw on the windshield frame with the one screw in the middle of the windshield sanction . They work very well with no vibration. They are made of solid round stock, and milled out to fit the windshield. Mine are the 6" ones and they don't stick out quite far enough for a touring with the top up.
https://www.snydersantiqueauto.com/Prod ... hByKeyword
[image][/image]
[image][/image]
1923 Touring low radiator
tdump
- First Name: Mack
- Last Name: Cole
With the shaky mirror you just have to learn how to bob your head at the same rate of speed so you can get a true view!
The middle rear view mirror I put on my pickup, is way to low to be of any use.So I am going to watch this thread and learn.
I bought my rear view mirrow and bracket from Snyder’s. Works pretty good with minimal vibration. I’ve had lighter mounted mirrows and in my case and probably most others the heavier mounting brackets helps to decrease the vibration.
Of course a T with a balanced engine would have the least vibration but you probably won’t get all the vibration out since it is a T to begin with!
In modern vehicles there isn’t any mirrow vibration from inside or outside mirrows. The reason being the heavy vehicles of today are more ‘solid’ because of the weight and generally run smoother.
- Last Name: Juhl
I bought a pair of these mirrors for my 1917 touring. They have the least vibration of others I have tried. A quality unit.
Barry Loucks
- First Name: Barry
- Last Name: Loucks
- * REQUIRED* Type and Year of Model Ts owned: 13, 22
John, you have no idea how hard it is to keep a mirror from shaking on a modern car. Sure they’re heavier because of all the extra things besides glass packaged inside that housing like power adjustment and turn signals and blind spot detection, but wind has a huge input. I’m happy to see 5 cars when there’s only one. Better than no cars when there is one.
Barry
Barry
Based on your concern - a shorter mirror arm will result in less apparent movement of the image in the mirror.
