HALL SCOTT "Ruckstell" early BRASS SHIFT LOCK BODY
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Post by StevenS » Sun Sep 13, 2020 1:25 am
I have a HALL SCOTT "RUCKSTELL" 2 speed rear end in my Model TT truck. It has both of the names on it, as an example of the naming, just like the shifting level that is in the first two pictures. But what I found interesting is the early shift lock body (in the 3rd and 4th pictures) is made of brass. So my question is; Has anyone seen a shift lock like that one before? I am thinking of removing the black paint to show it off. It also has an adjustable screw with a nut on it to keep the shift lock lever snug for a smooth action.
SHIFTING LEVER
BRASS SHIFT LOCK
The attachment TT REAR END Ruckstell brass shift lock #1.jpg is no longer available
The attachment TT REAR END Ruckstell brass shift lock #2.jpg is no longer available
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
Rod Petrie
First Name: Rod
Last Name: Petrie
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
Re: HALL SCOTT "Ruckstell" early BRASS SHIFT LOCK BODY
Post by Rod Petrie » Sun Sep 13, 2020 8:43 am
I have a spare brass one but am using a cast iron one,
Dan B
Last Name: Blaydon
Post by Dan B » Sun Sep 13, 2020 6:05 pm
That shifter lever is interesting. Wish they would have stuck with that design!
Post by Allan » Sun Sep 13, 2020 7:50 pm
I prefer the brass housing. It makes it far easier to ream a worn hole to take a thin wall bronze bushing to rebuild the thing.
Post by RajoRacer » Sun Sep 13, 2020 8:12 pm
The shifter handle is TT for sure - have seen many Hall-Scott brass car shifter bodies but not too many TT ones.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Sep 20, 2020 3:03 am
That TT shift lever is very similar to one for a TT Rocky Mountain Six Speed shifter. Interesting. Dave
1925 mostly original coupe.
