Back wood for 23 touring.
1923orange
First Name: Thomas
Last Name: Black
* REQUIRED* Type and Year of Model Ts owned: 1923 touring
Post by 1923orange » Wed Sep 16, 2020 12:33 pm
Any place that sells individual pieces of wood? I'm just needing the curved piece of wood that goes around the top back of a 1923 touring. The rest of my wood is fine. Thanks
1923orange
First Name: Thomas
Last Name: Black
Re: Back wood for 23 touring.
Post by 1923orange » Wed Sep 16, 2020 12:34 pm
Post by RajoRacer » Wed Sep 16, 2020 12:35 pm
Check in with Jon Anderson - R.V.'s brother - R.V. follows this Forum.
Post by John kuehn » Wed Sep 16, 2020 1:55 pm
Go to classicwoodproducts.
They are located in North Carolina and make wood frame kits and pieces for Model T’s. They sell the individual back wood pieces for Tourings also.
Hope this helps
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Wed Sep 16, 2020 3:35 pm
Jonathan Anderson will make that for you. Best if you call him, 716-499-7255
Post by Mark Gregush » Wed Sep 16, 2020 3:59 pm
Even the catalogs sell just the tack rail. I think you will need the whole unit, not just the curved parts. Just buying the curved parts does not mean they will match up to the rest of it.
Post by Allan » Wed Sep 16, 2020 5:33 pm
That bent rail is best made from steam bent timber to avoid the short grain across a cut curve. You can do it yourself by laminating strips of plywood using the body as your former.
Hope this helps.
