Does anyone know of a Ben Martin who repairs ignition switches, the number I have for him does not work. I am wanting someone who knows how to restore the plate and the white lettering thereon and I have heard that he is the guy. If someone else is out there that does this kind of work please let me know. Thanks
DanielSnell2@twc.com
1919-25 Switch Plate
SurveyKing
Topic author - Posts: 505
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
Re: 1919-25 Switch Plate
Daniel
Ben's phone # is 77 ZERO-938-33 SEVEN 6
You'll receive a nice rebuild if you provide a decent core, with key helps too, write a note on what you want too in the box with it, also if you want ammeter too, provide that for also.
Just got this one returned, powder coated plate, rebuilt switch with new center tumbler, added my own ammeter. The letting is left unpainted, but easy to add over the powder coat would think. White enamel paint with a superfine bush, then wipe off excess around letter with simple paint thinner, (not lacquer thinner), as paint thinner won't typically harm the powdercoat.
SurveyKing
- Last Name: Snell
That is a very good professional job. I'll be calling Ben, Thanks
Jahn_Wright
- First Name: Jahn
- Last Name: Wright
A fine tip white paint marker from the craft store works great for the letters. Since they are stamped into the metal, you don't even have to be an artist to do a great job.
Jahn
1925 Coupe--owned by my Grandfather
SurveyKing
- Last Name: Snell
Thank you for that suggetion on painting the letters white Jahn will give it a try.
