I'm sure other will respond to J-B Weld too.  Your problem is a clean surface for anything to adhere to. JD-Weld is used by many T owners to repair cracks etc. But rather than trying to glue the small pieces back on - you might just fill the gap with JB (careful no to glue the shaft)
As for the oil   20 Liters = 21 quarts so.....
API-SG oil was a formulation used in 1988 -1993. According to this it would be usable in cars prior to that yer but not later. The "S" designates for use with spark engines A "C" would be for compression engines)
http://www.pqiamerica.com/devilsindisguise.htm
JASO MA/MA2 a specification for Motorcycles using the same oil lubricating the engine and the wet clutch. Interesting spec!
https://www.oilspecifications.org/artic ... ASO_MB.php
There are a lot of opinions on oil viscosity and detergent versus non-detergent motor oil.  Viscosity choice should be based on the climate/season that the car is to be driven in. Multi-grade oils are a good choice for temperature ranges while a mono-grade would be better where the temperature range varies very little. Based on the amount of use of my car (low mileage); climate (all 4 seasons) the most practical choice is multi-grade.
Non-detergent oils were intended for engines without oil filters. They would cause the contaminated oil to stick to the engine walls and valleys to prevent the dirty oil form damaging bearings etc.. Detergent oils contain additives to keep the contaminates in suspension so the can be filtered out through an oil filter. There are many arguments for using one or the other - either way you need to first drop the inspection pan in the engine and remove and slug build-up before you  add your choice. Because the engine has no oil filter it is necessary to check your oil for cleanliness, and change or drop the inspection pan as required.
Lastly as is often mentioned in discussions about engine oil - if you use (or have) a magneto you should never use an oil containing graphite (most do not)
4-TAKT AGRO SAE 30 API SG
Corresponds with requirements / specifications / products:
TYPE 4-Stroke Engine Oil, SAE 30, API SG, JASO MA/MA2, Detergent Oil
http://sct.autodevel.com/en/?action=acc ... 20SAE%2030
