Holley NH idle circuit
mike zahorik
First Name: mike
Last Name: zahorik
Post by mike zahorik » Thu Oct 01, 2020 3:37 pm
On the Holley NH carburetor, why are there two idle circuit holes near the throttle plate? Seems that when the throttle is closed, the back, larger hole is on the non vacuum side side of the throttle plate and the smaller hole is on the vacuum side. Does the larger hole act an air bleed until the throttle is opened to the point where the larger hole is more influenced by the engine vacuum? Then the larger hole also provides more idle gasoline until the throttle is opened where the venturi starts to function? Thanks Mike.
Re: Holley NH idle circuit
Post by DanTreace » Thu Oct 01, 2020 4:38 pm
The Service Bulletin explains these two holes, Extreme Idle D and Low Speed E.
IMG_4452 (630x640) (591x600).jpg (155.14 KiB) Viewed 1847 times
Post by Steve Jelf » Thu Oct 01, 2020 11:48 pm
Here's a little bit better copy. Volume 5, #2 — February 1924.
mike zahorik
First Name: mike
Last Name: zahorik
Post by mike zahorik » Fri Oct 02, 2020 7:00 pm
Thanks, Mike
