26-27 Engine Pans
ModelTWoods
Topic author - Posts: 1554
- First Name: Terry
- Last Name: Woods
26-27 Engine Pans
Can anyone post a photo of the CORRECT engine pans for the improved (26-27) cars. I see the ones shown in Lang's catalog, but would like to see something clearer and closer up. Please post only if you are sure the photo you post is correct (no guesses or "I think so".
Dan B
- Last Name: Blaydon
Re: 26-27 Engine Pans
ModelTWoods
- First Name: Terry
- Last Name: Woods
Well, its obvious that I have an incorrect set of pans. I need a set with the two hole right side, like Larry mentioned as I have a 27. I do plan to run a conventional intake and carb, but would like the ability to install my vaporizer, if I ever desire to.
- Last Name: Hatch
Email me at address in pictures. I think I have found another set of original ones. Dan
- Last Name: Patrick
In 2010, I bought a set of ‘26-‘27 engine pans From Snyder’s for the right and left side of my 1926 coupe engine. They are installed between the engine and chassis so they are perfectly level. The set I bought back then fit perfectly and they are very handy for Holding tools and catching dropped nuts, bolts, washers and cotter keys when working on the engine. I see no reason why a design that fit my car so perfectly In 2010 would have been changed, so what is sold now should be the same. Jim Patrick
