Radiator Fan Assembly
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I removed the fan assembly from my 1927 coupe. The surface area where the hose fits over is corroded. Will this result in leakage when the new hose is installed? Another question: The other parts of the assembly look good. If I reuse it, how likely is it that some grease will leak and make a mess? Maybe I should upgrade the whole unit as available in the catalogs. Any comments?
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Re: Radiator Fan Assembly
Clean the surface by bead blast or sand blast and lay a coating of JB Weld on the pitted area. When cured, sand down to surface and you will be good for years. JB Weld can be used to surface deep pitted sheet metal. I have used it with great success many times. Ken
Work honestly
Stay true to your word
Get the job done right
