The hardened sleeve 2596 didn't appear until 1911 with the tapered end driveshaft, where the pinion gear is held by a nut and cotter pin, instead of the pin rivet arrangement.
The Driveshaft has a hardened end step that the roller bearing 2890 ran on (not sure how, probably case, it would be easiest). I'm assuming that it was deemed much cheaper to make a separate sleeve, harden it and just press it onto the end of the shaft rather than this method, which I can see there being some problems with, especially fitting that rivet.
***1910-1911 2 Piece Driveshaft Cross Section***
VowellArt
Topic author - Posts: 579
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Fun never quits!
VowellArt
- Last Name: Vowell
Re: ***1910-1911 2 Piece Driveshaft Cross Section***
Slight change, had to change the lock screw 2586 (a bit too short).
Fun never quits!
VowellArt
- Last Name: Vowell
Slight change to spool and thrust bearing.
Fun never quits!
VowellArt
- Last Name: Vowell
I think this may be the what this looks.....
Fun never quits!
Alan Long
- First Name: Alan
- Last Name: Long
Doesn’t the Universal Joint run against the bronze thrust / bush in the earlier units?
Alan
Alan
Alan Long
- First Name: Alan
- Last Name: Long
Martyn.
Looks perfect to me! Thank you for the great work you do with your drawings
Alan in Western Australia
