Position of burner
dykker5502
First Name: Michael
Last Name: Deichmann
Position of burner
Post by dykker5502 » Thu Oct 08, 2020 7:14 am
Hi,
I received my headligths from Ross Benedict and they look great.
During assembly of the burner, I am in doubt what is the correct position of the "Y":
I believe "A" is the right?
Ford Model T 1914 Touring
First Name: Keith
Last Name: Townsend
Re: Position of burner
Post by KWTownsend » Thu Oct 08, 2020 7:30 am
Image A. Front to back.
You should not see the Y from the front.
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Thu Oct 08, 2020 8:27 pm
Isn’t the point of the “A” configuration to cause the gas streams, when they hit each other, to create a wide/broad flame for greater reflected illumination?
Darin
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Thu Oct 08, 2020 8:33 pm
To help line up the burner,
I use a dab of pipe dope on the threads of the burner base
to keep the acetylene from leaking around base of the burner.
I like my burners "snug" on the base but not so tight I can't reach
in there with my fingers and line up the flame when lit.
I have a burner that makes a great flame but is crooked relative to the Mangin.
Slight twist of the burner lines the flame up and it stays put.
HARVEYS DOPE.jpg (53.21 KiB) Viewed 2169 times
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Oct 09, 2020 10:10 am
“A” is correct for getting the most light and is the way they were originally aligned. However, with whatever is in there in place of a reflector, it is doubtful that the headlamps will produce enough light to drive by no matter what you do.
Terry_007
First Name: Terry
Last Name: Bond
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Post by Terry_007 » Fri Oct 09, 2020 11:20 am
Thought this diagram might be of interest.
Headlamp burner diagram.jpg (43.05 KiB) Viewed 2090 times
dykker5502
First Name: Michael
Post by dykker5502 » Sat Oct 10, 2020 6:01 pm
That diagram was nice!
Thank you all.
